| | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2023 Posts: 72 'Bolter | | 'Bolter Joined: Dec 2023 Posts: 72 | Sorry guys but I've danced around trying to figure out/verify my engine and I'm not having much luck. So here's my data if anyone has the investigative skills to decode: 1959 Chev 3100 inline six: 3764476 (found on block by starter motor) 3836848 (on top of head-drivers side) F218J {machine flat area behind distributor) note: the number 1 could be the letter I
Thanks for the help. I'm assuming it's the original235cu engine but want to confirm
1959 Chev Napco 4x4 3100 w/235cu
| | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | This site indicates that your engine is the right year range to be original. Hard to nail down exactly.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2023 Posts: 72 'Bolter | | 'Bolter Joined: Dec 2023 Posts: 72 | Thank you sir, So it appears to be 235cu, 58-62, by block and head. F218J= Flint, Mich, Feb 18th, 3100-3800 models Another sire from the one you posted: http://devestechnet.com/Home/CastingNumbersThank you very much, nice for the confirmation, Keith Hansen
| | | | | Joined: Jul 2014 Posts: 1,289 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,289 | Along with Kevin's information , using the the Engine number F218J breaks down as F = Flint Michigan 218 = February 18 J = 3100 -3200-3300 Regular Production
So it is very possible you have the original engine.
Info taken from 1959 Chevrolet Truck Specifications Manual found at GM Heritage Site.
( edit - looks like we were both typing at the same time, I'll leave it....)
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Dec 2023 Posts: 72 'Bolter | | 'Bolter Joined: Dec 2023 Posts: 72 |
