| | | Forums66 Topics128,162 Posts1,056,933 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 243 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 243 | im looking to replace my cab rubber seals to make as 100% water tight as poss, are these the same seals as a 1/2 ton 48????, whats the best oil to run in my 20,000.00 orig mile 235 loadmaster engine??? trans fluid?? rearend fluid??? | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Any of the usual vendors can supply window and door rubber seals for the pick ups and they should also work on your cab.
Any quality 20W oil will work fine in your engine. Some use multiweight oil and it is OK too. Standard 90W gear lube for tranny and rear. | | |
