0 members (), 133 guests, and 2 robots.
Topics128,132
Posts1,056,729
Members48,454
im looking to replace my cab rubber seals to make as 100% water tight as poss, are these the same seals as a 1/2 ton 48????, whats the best oil to run in my 20,000.00 orig mile 235 loadmaster engine??? trans fluid?? rearend fluid???
Any of the usual vendors can supply window and door rubber seals for the pick ups and they should also work on your cab.
Any quality 20W oil will work fine in your engine. Some use multiweight oil and it is OK too. Standard 90W gear lube for tranny and rear.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
