5 members (texas46, Jaison, Hotrod Lincoln, JW51, WICruiser), 148 guests, and 3 robots.
Topics128,082
Posts1,055,961
Members48,430
#1530890 12/29/2023 2:48 PM
AD Addict & Tinkerer
What do you guys/gals recommend for media in your blast cabinets?
I’ve previously used 80 Mesh Glass Abrasive media from Tractor Supply. It worked well but pretty slow.
Phil
Project Journals
Stovebolt Gallery Forum
Phak1 #1530902 12/29/2023 4:29 PM
60 grit Red Garnet
Phak1 #1530916 12/29/2023 7:07 PM
Sir Searchalot
Sir Searchalot
I use this from T/S. They have fine and medium. I use med.
Click
Phak1 #1530917 12/29/2023 7:10 PM
Depends on what you're blasting. the finer grit glass is better for sheet metal, but the coarser (coal slag that bartamos linked) is faster for heavier metal pieces.
Phak1 #1530947 12/30/2023 12:46 AM
I guess I’ll try the coal slag in a medium grit. Most of the pieces I want to blast are heavy steel brackets. I do like the finish the glass media gives but it is pricey and it takes too long.
Thanks!
Phil
Project Journals
Phak1 #1531003 12/30/2023 3:57 PM
Crusty Old Sarge
Crusty Old Sarge
I have used Coal Slag with mixed results, it seems to take awhile to remove heavy rust. Alvin swears by #45 sand, I haven't been able to find locally.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Phak1 #1531020 12/30/2023 7:09 PM
The red garnet I've mention has done any part off the Suburban I can fit in to the cabinet. The complete Model A Roadster because, when broken down, all panels fit in the cabinet, and now I'm starting in on the Tudor. No heat, no warping and perfect grip for paint. Even the worst rust is no match for it and it works quickly. It will wear blaster cabinet parts so it helps to have some of the tubes and hoses in stock. And some of the protective covers for the window. Some before blasting, after blasting and after paint of the axle I did recently.
Phak1 #1531080 12/31/2023 4:29 AM
I have glass beads, black diamond, plastic in my shop with skat blast cabinet
........but always prefer #45 fine sand. It does a good job and a nice finish for most stuff.
I get mine at the local brick and block place for $5 per 50lb bag......i also dump only 1/2 bag in at a time and change often to have nice clean sand.
J Online: Content
Nicer finish than my "wire wheel and rattle can" approach.
Weird.
1951 3100
JW51 #1531139 12/31/2023 6:15 PM
Weird.
Gets in those pits a little better and quicker than those wire wheels. I can't remember the last time I used a wire wheel, even one mounted on a grinder stand. Nuts, bolts, everything goes in that blast cabinet.
Phak1 #1531336 01/02/2024 4:23 AM
J Online: Content
How can that possibly replace the satisfaction of covering oneself, and everything in sight, in dusty grime? And then stepping back and admiring your 75% rust-free metallic object?
1951 3100
Phak1 #1531394 01/02/2024 6:11 PM
I got tired of those little wires fighting back every once in a while!
J Online: Content
That is a distinct downside of the wire wheel approach.
1951 3100
JW51 #1531442 01/02/2024 11:19 PM
Sure is. I've had to extract a few wires from my legs. The little buggers can go right thru a pair of jeans. eek
Phak1 #1531450 01/02/2024 11:53 PM
Just picked up 50 lbs of medium grit black diamond coal slag to give it a try tomorrow. I also picked up two twisted wire wheels for my side grinder on sale at TS for half price. Although they do spit wires, some of the pieces I need to strip, won't fit in my desktop blaster!
Phil
Project Journals
Phak1 #1544484 04/19/2024 1:34 PM
Medium grit black coal slag from TSC gave me good results on this bracket. I used the fine grit for the interior of this 1934 Chevy Master coupe.
Phak1 #1544504 04/19/2024 8:37 PM
A blast material should get into the pits and clean them out.
Phak1 #1544545 04/20/2024 2:04 PM
back yard wrench turner
After blasting, I use phosphoric acid treatment on the metal. It coats and prevents any further rusting. Particularly good if you aren't going to paint right away.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Phak1 #1544610 04/21/2024 2:48 AM
I use Ospho on parts which I don't plan on epoxy priming. Epoxy primer does not get along with Ospho unless the part is meticulously cleaned of all of the byproduct of the chemical conversion done by the Ospho. I don't risk it for body panels which I have to pay a painter thousands and thousands of dollars to apply.
Phak1 #1544824 04/23/2024 11:52 AM
I recently changed my cabinet media to fine grit instead of medium grit. Efficiency improved at least 50%. I think I'll stay with fine grit for most everything.
Phak1 #1568211 01/16/2025 11:27 PM
Years ago when we were restoring North American T-28 Trojans we used crushed walnut shell medium to paint strip the insid of the fuselages.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Moderated by  MNSmith
