4 members (farmallb, Gib70, Gdads51, Nick in Manitou), 132 guests, and 3 robots.
Topics128,088
Posts1,055,998
Members48,430
Howdy Folks,
I cannot get my original shift knob off the arm of my three on the tree shifter. I know it seems silly, but is there a trick to it...?
All ideas are welcomed:
Is there a reason you need to get the knob off? If it needs to be replaced, just break it off. You can probably split it with a hammer. I think replacements are available from the usual vendors.
Mine was OK, so I just masked it off when I painted the shifter lever.
As a lot have espoused, there is nothing like the original. nono
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
The knob that is on there now is a little chipped up. I was looking for an easy and inexpensive, quick fix that I could diy - but I have tried to turn it off and it won't budge.
If I break it off, do the new ones thread back on or....?
Plus, I think it's the wrong color. I think mine is black but it should be a brownish-maroon color, right....?
Yes
No, they press on
Hi, thanks for the great info and picture. Very grateful. So they just press on...?
The original knob is bakelite, an ancient form of plastic. Unlike plastic, it avails itself to repair by filing, sanding and polishing.
The replacement knobs are not the right color.
I restored an antique turn signal which consists of a large round body made of bakelite. It was a mess from oxidation. I was able to bring back its original luster by using sandpaper from coarse to 800 grit. I then polished it on a bench mounted buffer.
Holy Moley does that thing pop now. It has a tortoise shell look to it due to the marbling in the bakelite.
That sounds like a beauty
FWIW, some bakelite has asbestos in it. Sanding, grinding and/or buffing could cause it to become airborne and inhaled. Granted, disease from asbestos is years down the road from exposure and likely takes a significant exposure, but I'd steer clear. I'm speaking from the perspective of someone that worked for many years in a building that was known to have asbestos in the floors, ceiling and around the lead pipes....
Mike
1953 3100
The Gray Ghost
My Project journal
If you decide to remove and abandon the old knob, try this:
Clamp a large vice grip onto the knob.
Release vice grip and adjust it a partial turn tighter , then re-clamp.
Repeat this process in small increments until the knob gives up and fractures.
Works pretty much every time.
Thank you Gray, good to know.
Thanks for the tip, I will see.
Use a dremel tool with the little thin cutting wheel. Its a handy tool.
That would be handy, but I wish i had one. ohwell
Are you trying to save it or destroy it, to get it off? I wouldn't do anything until I had a replacement in hand...what you have is better than nothing.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
That is true sir! I imagine it is the original, because the shifter knob is a faded brown color. I got a new lower vent knob, because it was missing when I bought the truck, but it is a brand new shiny-brown maroon. I wish they matched in color...
Dremel tools are inexpensive and have many applications.
How much are they Waveski...?
A Dremel tool can be had for as little as $30, but a full kit goes for about double that with bits and other accessories.
Knockoffs can be as little as $12.
Link
There's tons of them in ePay and Amazon...this one looks like a good kit with lots of bits for $23
https://www.amazon.com/JORGENSEN-Rotary-Variable-Accessories-Powerful/dp/B0BGLRMFGN
Mike B smile
Last edited by Peggy M; 01/02/2024 3:47 PM. Reason: fixed link to remove tracking data
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Good deal on the one Mike posted. If you know someone with Prime let them order it free shipping!
I actually have two. You'll use it more than you think.
Great info guys, thanks!
It’s one of those gotta have it tools.
