| | | Forums66 Topics128,018 Posts1,055,259 Members48,417 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | The heat riser on my 228 is stuck. I have been spraying liberal amounts of PB And tapping each end with a small hammer for some time, but I can’t get it free. What are my options? I would like to avoid removing the manifolds.
What ill effects are expected with a stuck open heat riser?
Mike Barnes 1950 GMC 1-ton pickup
| | | | | Joined: Dec 2020 Posts: 1,953 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,953 | Other than heat ,PB and patience. Will it move at all?
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
| | | | | Joined: Jul 2014 Posts: 1,289 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,289 | Unfortunately you will have your best chance at getting it free by removing the manifold, seperating the intake and exhaust and then removing as much buildup from the inside , continue to soak and tap left/right, repeat. applying heat ( torch , propane, etc... ) on both sides and then spraying with PB or Kroil and let it sit. Be carefull as both are flammable at some temp. It take a lot of patience but it can be done. It took me a couple of days to get mine freed up. I got very discouraged with the waiting for the PB to do its job.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Feb 2016 Posts: 1,982 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,982 | Heat is the trick, oxy-acetylene with a small welding tip may be the answer so you can pin-point the flame at the casting, not at the shaft. Heat the cast till it's barely dull red on both sides, try to turn the shaft, if it won't move, let it cool completely and tap the shaft end.
| | | | | Joined: Feb 2019 Posts: 4,471 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,471 | While it’s cooling, not when it’s red, spray a little bit of penetrating oil on both sides. The heat will help draw the penetrant in. Allot of patience is required and you don’t want to force anything. The last thing you want to do is snap the shaft off. This can be fixed but it requires allot more work. Tapping the shaft back and forth helps break the rust bond. Once you get it moving, spray more penetrant and keep working it back and forth. Good Luck!
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Dec 2020 Posts: 1,953 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,953 | Mine really freed up after I had it blasted. Not sure if you could leave it attached and use a gun of sorts to focus blast. Tapping back and forth and time.
| | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | Heat and candle wax. Get the manifold around the shaft hot- - - -dull red is about right, then apply a wax candle or a block of paraffin from the canning department of your local grocery store. One package of paraffin will be a lifetime supply for several people. I use it when making cast bullet lubricant by the pound, along with beeswax toilet sealing rings and general purpose chassis grease. Jerry
| | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | Thanks for all of the advice. Removing the manifolds will be my next project.
After the truck gets really hot it won’t start until it cools down. I hope correcting the heat riser issue will solve the problem.
