| | | Forums66 Topics128,070 Posts1,055,900 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 190 | I just found out my 47 has a Rockwell 2 speed rear end. Do you guys know is that the axle that a COE would of came with in those years? I have heard of Eaton 2 speeds. I am pretty much a novice at these old trucks, but I had not even heard of a Rockwell before. I could not find it named in my manual, just was curious. I have a friend looking at a 53 6400 - would that be a Rockwell 2 speed also? and the correct engine a 235? Thanks for any info, Tom. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I'm not as sure about the '41-early '47's, but the late 47-'55's would have had a Timken 2 speed rear axle in them. My '46 Chevy conventional 2 ton, has a 2 speed Timken rear axle in it also. You would more than likely find a Eaton rear axle in a GMC. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | A quick look in my Chevrolet Master Parts Catalog, shows the same vacuum shift Timken 2 speed rear axle, listed for all '46-'55 1st series, Chevrolet 2 ton trucks. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | The 53' should originally have come with a 216 or 235 babbited engine.
Jeff | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I think that all 1947-53 Chevrolet COEs came standard with the low-pressure 235 engine.
In 1954 the high-pressure 235 engine was standard on all Chevrolet COEs and the new 261 engine was an option. | | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | Yep, Vacuum Timken 2spd rear in my truck too. | | | | | Joined: Feb 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 190 | Thanks for the info guys, dont know what my brother in law is going to do about the 53 yet but I passed the info to him thanks again. | | |
