| | | Forums66 Topics128,022 Posts1,055,376 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 28 Apprentice | | Apprentice Joined: Apr 2007 Posts: 28 | Does anyone know where to get front dust caps for a 1.5 or 2 ton mine are missing. thankyou
sorry, caps for the front wheel bearings | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | fil shaffer.
I don't think the caps from a 1 1/2 ton will interchange with a 2 ton. The 1 1/2 ton screws or taps on and the 2 ton has five small bolts holding it on.
Stuart | | | | | Joined: Apr 2007 Posts: 28 Apprentice | | Apprentice Joined: Apr 2007 Posts: 28 | thanks atomarc
Mine has the screw in type Im still trying to figure out if this is a 1.5 or a 2 ton i didnt relize the difference in the caps. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | fil shaffer,
If it has the screw in type and not the bolt on type , you know the front axle is 1.5 ton....so, if no one has swapped axles (not likely) your truck is a 1.5 ton rig!
Stuart | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | My coe has 4 bolts on the front and its a 1 1/2 ton... The 41' 1 1/2 ton has the entire cap that is threaded and covers the bolt, while Oldsubs 53' coe has 6 bolts that hold the cap on.
Differences in years and hubs, makes and models???
Jeff | | |
