6 members (CATMAN, tclederman, BarryP, DadsFirstPickup, Bill Hanlon, Millenimech), 95 guests, and 4 robots.
Topics128,154
Posts1,056,842
Members48,456
#152923 05/26/2007 9:00 PM
We replace a couple wheel cylinders and rebuilt the master cylinder. When we took the truck out the brakes built up and started smoking. We opened the bleed screw o a couple wheels and it squirted fluid out. the brakes were okay for a few miles and started smoking again. Had to bleed a little fluid again. How full do I leave the master cylinder? Is there something else I need to look at? 3 of four wheels were very hot. Thanks for suggestions.
Red meat is not bad for you.........Fuzzy green meat is bad for you!
"What happens in the garage stays in the garage!"
1958 Chevy Spartan 100 firetruck in the Gallery
#152924 05/26/2007 9:24 PM
Is the return spring attached to the peddle to bring it back to the top, or is it missing and you are effectively riding around with your foot on the brake?
If it does have the spring then the push rod could be adjusted too long, keeping pressure on the wheel cylinders. You would need to adjust it to have a little free play with the peddle at the top.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
#152925 05/26/2007 9:56 PM
the mstr cyl should be full ..... your rubber hoses are probably rotten - collapsing inside they'll keep the pressure on - otherwise you've done something wrong on assembling the mstr cyl
hey wait! firetruck - hydrovac - if it has one did you bleed it? did you check it? did it get reconnected right?
#152926 05/27/2007 2:30 AM
Thanks Grig, the spring is attached. You have to depress the pedal maybe 1/3 of the way and it is very consistant. We bled two quarts of fluid until it was clear from each wheel cylinder.
We did not touch the hydrovac, will need to check that monday.
Thanks for the ideas.
Larry
#152927 05/27/2007 3:54 AM
Hey Larry make sure the push rod is letting the piston in the master cylinder return far enough to let the fluid return to the reservoir like Grigg was getting at.
red58 has a good point also, sounds funny but I have seen rubber brake hoses that had rotted on the in side and would let fluid go one way but not the other like a check valve.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
#152928 05/27/2007 5:01 AM
If the rubber hoses look cracked, I would replace them anyway. Like most people, I used to only replace them if they blew or were leaking. But last year I helped get a '54 F**d up and running. Everthing was fine with all new brakes until the owner pulled out of the driveway, drove a 1/4 of a mile downhill and stepped on the brake pedal. The front drivers flex hose blew out on the fitting and he had to ditch into the barrow pit. Took about 300 yards to stop. Ever since, I have encouraged everyone to just replace them if they show any small cracks at all. I know this doesn't apply directly to the topic, but seeing a big bolt without brakes isn't something you like to see.
Terry Wofford
'52 GMC 3 1/2 Ton
'51 GMC 2 1/2 Ton
'53 GMC 1 1/2 Ton
'53 Chevy 2Ton
"If it ain't broke, well give me the keys and I'll be right back!"
#152929 05/27/2007 11:11 AM
The rubber hoses looked good on the outside but no way of telling what is on the inside. This makes sense, the hydraulic pressure is so much greater than the springs that return the fluid. The truck has eight wheel cylinders, one for each shoe. Thank to each of you for the input.
#152930 05/27/2007 3:28 PM
Riding in the Passing Lane
A rubber hose can cause this problem but it is confined to one front or the rear brakes. I think your problem is in the master cyl or pedal push rod. It is not letting the master cyl. piston go back all the way.
1972 Chevy c10 Cheyenne Super
#152931 05/27/2007 9:05 PM
Hey, thanks, I will start with the master cylinder but may go ahead and order new lines to be safe.
#152932 08/12/2007 10:23 PM
I replaced the rubber hoses and rebled the brakes. Still having problems with the pedal building up and brakes won't release. Have to bleed 1 or 2 wheels to relieve them.Anybode know how the vacuum booster works and is ther something to rebuild there?
#152933 08/12/2007 11:40 PM
Back the shoe adjustment off a couple of notches so they aren't rubbing. It's causing heat expansion which applies the brakes more and more the further you drive.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#152934 08/13/2007 2:45 AM
This truck has a wheel cylinder for each shoe with no provisions to adjust. I now believe the problem is either the slave cylinder at the hydrovac or the master cylinder is bad. will check that angle next.
#152935 08/18/2007 4:37 AM
We removed the master cylinder today and found one of the two holes from cylinder to the reservour was clogged. The larger one (1/4 inch) was fine but there was one about the size of a stick pin that was clogged. Hopefully it is fixed. Thanks again for all the input!
Larry
