| | | Forums66 Topics128,132 Posts1,056,376 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | The latest from Jon G -- The Ernest Hemingway of engine Tech Tips!! Jon shows how to make some spreaders to seal your valve cover and stop those annoying leaks! The Tech Tip is posted HERE
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jan 2014 Posts: 3,689 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,689 | Very nice! Jon’s solution is likely more effective and better looking than my theorized solution. On my “when I get around to it” list is to grind some width out of the widely available SBC valve cover spreaders. I think they could be made to fit. This is the kind of thing I’m talking about: https://www.autozone.com/external-e...alve-cover-load-spreader-5321/228340_0_0What little oil seeps from my valve cover is it noticeable enough given the seeps from other areas. Based on advice given here, I have done “part” of the tech tip. The tinsmith work to flatten the bolt holes and my VC is glued to the head with Permatex super 300.
1951 3100
| | | | | Joined: Oct 2019 Posts: 449 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 449 | Great idea, but I'm curious as to why these are made from aluminum rather than steel?
Kevin 1965 Chevy C10 Longbed Fleetside
| | | | | Joined: Feb 2004 Posts: 29,811 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,811 | Here's enough spreader bars for two engines- - - - -might need a little tweaking with a bench grinder to make them fit a stovebolt six- - - - - www.ebay.com/itm/192972613053?Jerry
| | | | | Joined: Mar 2014 Posts: 4,501 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,501 | Thanks! I had aluminum handy and it cuts okay with a saber saw. Besides aluminum that thick will provide enough "springiness" and I wanted pressure extending all the way down the sides and to the back and front corners. This was done a while ago and leaks haven't been a problem since.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Oct 2019 Posts: 449 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 449 | I see. Thank you for the tip. I will definitely fabricate some for my new engine. Hate to have a newly painted engine and then have oil leaking on it
