2 members (J Lucas, JW51), 266 guests, and 1 robot.
Topics128,081
Posts1,056,074
Members48,434
#152838 05/20/2007 3:23 PM
When running freeway a while back started noticing a new sound, several hundred miles later. That sound has become one heck of a Howl !!! My rear leaks quite a bit and I got under there to check it - well I think I was all but out of oil. Filled it up, but I need to get the leaks stopped and I think maybe new bearings. What do you think? While driving, the noise gets worse at about 22 - 32 mph. Almost no noise below that and after that it gets less notice able. But it really sounds bad and at the worst, it sounds horrible.
Does anyone know someone you could recomend in So Cal that could replace the bearings and or rebuild this? I beleive its a later eaton 2 speed - something after 47 anyways. Theres a fleet pride truck repair place here in town I am going to talk to this week, but hopefully you guys might know someone, thanks Tom.
#152839 05/20/2007 3:53 PM
You may save money by just buying a better used rear and just installing hub seals
Bearings and seals and labor will soon add up to more than the rear axle ws worth. You may find it is junk inside when you take it apart any how.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
