2 members (delky, Steelonsteel),
235
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 190 | When running freeway a while back started noticing a new sound, several hundred miles later. That sound has become one heck of a Howl !!! My rear leaks quite a bit and I got under there to check it - well I think I was all but out of oil. Filled it up, but I need to get the leaks stopped and I think maybe new bearings. What do you think? While driving, the noise gets worse at about 22 - 32 mph. Almost no noise below that and after that it gets less notice able. But it really sounds bad and at the worst, it sounds horrible. Does anyone know someone you could recomend in So Cal that could replace the bearings and or rebuild this? I beleive its a later eaton 2 speed - something after 47 anyways. Theres a fleet pride truck repair place here in town I am going to talk to this week, but hopefully you guys might know someone, thanks Tom. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You may save money by just buying a better used rear and just installing hub seals Bearings and seals and labor will soon add up to more than the rear axle ws worth. You may find it is junk inside when you take it apart any how.
Grigg | | |
