2 members (gswbbc, wilbur53),
139
Mod | | | Forums66 Topics128,035 Posts1,055,446 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 25 Apprentice | | Apprentice Joined: May 2007 Posts: 25 | Hello, im new to this forum i recently just purchased a 1969 Chevy Dump Its a bigger dump, What you would say a medium to heavy. Its a Body type TK. I dont know what that means. It has a chevy 350 in it. first couple questions. are. If you could please help me. 1. Where do i find body parts for it to make look rust free.? 2. It drives awefully slow. I dont know if theres something wrong with it, or is it suppossed to sound extremly high in rpms when being driven like 30 mph seeming like its the as fast as you can go? 3. Whats the 5sp tranny is in it. ? 4. i have no gauges that work is that all in the wiring.?
Thanks if you can help me im very retarded when it comes to this truck im use to fuel inj, and going old school is making me suffer. lol | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Welcome to the Stovebolt Pages. I'm moving this to the "Big Bolt" forum because that's where the big truck experts are. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | 2. Could be your two speed rear axle is stuck in low. You should be able to get up to 50 or so with out the engine screaming to much. 3. Check for a tag on the transmission, probably right side near the top. My guess is it is a Spicer 5 speed direct drive. 4. Gages will be mostly electronic. Check for blown fuses, a good ground for all your gages. And if that does not fix them get a service manual and follow the instructions.
Grigg | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I don't know what TK mean. Does it have badges with C-xx on the cowl? What size are the tires and how many lugs on the rear wheels? Does it have a 2-speed rear axle?
30 doesn't seem fast enough, but if you are used to driving things that sit low to the ground the percieved speed sitting up that high might be slower than you are really going. You might be going more like 40 or 45 thinking its only 30.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | welcome, i think Grigg might be on the right track for you 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: May 2007 Posts: 25 Apprentice | | Apprentice Joined: May 2007 Posts: 25 | Ok i will check into all of that thanks, Im not sure theres no badging on it what so ever, And the rear wheels have 920 tires. im not sure the lugs i will check that. | | | | | Joined: Mar 2007 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 33 | And a picture is worth 1000 words...could be that a snapshot might help some of the guys figure out just what it is that you've got.
People keep asking what I want to do when I grow up. I don't understand the question.
| | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | Sounds like a c60? As for body parts good luck. I have a 1970 C50 same as a C60 and live in the north east so there aren't any body parts in junk yards here. I've been doing a lot of welding and patching. I can tell you that rockers for a pickup can be modified to fit , you have to trim some off the front. cab corners are a direct fit. floor pans require slight modification vs pickup. The doors are the same except the front lower corner is cut off. any front sheet metal is totally different. Welcome, there is a lot of good folks here and tons of info. I could not find much info on the last of the big bolts like ours any where but here.
1970 C50 dump! saving orphans from the CRUSHER
