| | | Forums66 Topics128,007 Posts1,055,279 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2000 Posts: 173 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 173 | Hi all, I added a couple of paragraphs to Lurch's Gallery Forum last night and when I clicked the Change Post button, the post was republished, but the HTML coding in the post no longer works. For example, bulleted lists and urls. Here's a link to the post: https://www.stovebolt.com/ubbthread...1927-chevrolet-lm-1-ton-truck-lurch.htmlAny ideas? Thanks, Dean | | | | | Joined: Jul 2000 Posts: 2,187 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,187 | You may have accidentally changed your post options. It's a drop down list you can see in the full editor. Change post options to "HTML and UBBCode"
Test
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jul 2000 Posts: 173 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 173 | Thanks for the suggestions.
My Post Options only has one option: HTML only. The HTML and UBBCode option is not there.
??? Dean | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | Dean,
I fixed it for you (temporarily). Baldeagle may need to look at it to see why you don't have the option for HTML and UBB Code.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2004 Posts: 5,066 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,066 | My Post Options only has one option: HTML only. The HTML and UBBCode option is not there. That's correct and it was set up that way. Because ... many of the entries were not following the Guidelines established for that forum, we had to limited the permissions. Working with a Team, we were looking for some quality posts to go along with all the images (25). This didn't work out so well and we had more problems in there than we planned for. Plus, the UBB software didn't allow us to do the *reviews* like we were hoping for. Nor were we able to move a thread to a better forum. (Gallery can only move to another Gallery ... in our case to the Daily Driver Gallery ...  ) So of late, we are holding up approving an entry until we have time to check them and get some feedback to our questions to the OP. That didn't work out so well either. So, we are putting all that effort back into the DITY Gallery. That forum has proved to be what it was set up to be, with just a little tweaking here and there. And we add some features to make them more like the legacy Gallery.
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Jul 2000 Posts: 173 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 173 | Peggy, thanks for the explanation.
It seems that in my case, the original post was approved, thus enabling the HTML. However, when I edited it later to add a couple of paragraphs, the post reverted to needing to be approved again? That doesn't sound logical. Once approved, my opinion is that the post should remain approved, even for future edits.
My 2 cents.
Thanks, Dean | | | | | Joined: Apr 2004 Posts: 5,066 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,066 | Dean,
The downside in only adding to your original post is that it does not show up in Active Threads. In one respect, the Gallery Forum is like a legacy Gallery story. The original story was put up on the site. If a small tid bit was sent in later, we only adjusted the story. If it was substantial, we actually did a real UPDATE with a new date. This allowed readers to follow the story of the truck. Some folks gave an update every year or so, which was great. That thinking (and the increase in the number of these updates / changes) triggered the idea of a DITY Gallery. With the DG, folks could basically update their truck stories as they were so led, and still we could follow the truck's history.
Keeping the approval-requirement, gives us a chance to again connect with the OP to see what we can work out with them and their story of the truck.
Peg
