5 members (Bill Hanlon, 52Carl, Otto Skorzeny, SmalltownTRKGuy, 1 invisible), 80 guests, and 3 robots.
Topics128,094
Posts1,056,058
Members48,433
I have a '54 3100 that I’ll be installing the running boards soon. I’m doing a full restoration on the truck. I was wondering if anyone puts some type of an isolator between the bottom of the running boards and the top of the brackets they mount to? I don’t think they had anything there originally. Maybe over thinking. Just easier to do something now than later. Thanks.
Adam
Adam
The running boards did not have anti squeak or other material between the running boards and the mounts. Things to consider - you need to be able to adjust the running boards laterally when you install them. The bolt holes in the running board at the rear need to line up with holes in the rear fender. The splash apron height / clearance to the bedside would be affected by putting anything under the running boards. Its also likely that adding material would allow water/ moisture to get trapped and set up the potential for corrosion. The original design has withstood the test of time.
Ron - - Dusty53
1954 Chevy 3604
Thanks for the comments. I can see how it could possibly throw off the mounting to the fender and filler panel alignment. I was thinking something fairly thin and at this point I need to mount all those components so I do have some adjustment there now. As far as moisture mine did have a little rust in those spots but not to bad. The big moisture area was where the running boards met the fenders. Those areas on mine were shot both sides and I think that’s pretty common. That’s an area where the original design I think was flawed. But then again I’m sure GM wasn’t planning on a bunch of guys 75 years later wanting to restore these trucks.
Adam
O Online: Content
I'm sure your truck isn't going to see anywhere near the kind of use it did when it was new. The likelihood of rust in any of the areas mentioned is slim to none.
1950 Chevrolet 3100 (Ol' Roy)
5 Online: Content
Anything which you put there will hold water and may cause more trouble down the road than without it.
A thin piece of Teflon is what I used on mine just so it was not metal on metal ,might help with squeaks as well .I had thin rubber there before that lasted but I don’t think there was anything there from when new.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
