0 members (),
102
Mod | | | Forums66 Topics128,275 Posts1,058,572 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 615 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 615 | I read this just for fun. Wow, those were the days! I think the section on adjusting the brakes was as long as the section on rebuilding the engine :-D Kidding, but seriously any mechanically inclined farm hand could keep this thing on the road pretty much forever.
| | | | | Joined: May 2015 Posts: 11,282 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,282 | I found it interesting that the connecting rods in 1933 6 cylinder engines were pressure oiled thru a drilled crankshaft, while the 216 engine of the AD series trucks had dipper oiled rod bearings. One guy I've talked with called them "splash and clatter" engines.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2004 Posts: 6,242 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,242 | I found it interesting that the connecting rods in 1933 6 cylinder engines were pressure oiled thru a drilled crankshaft, while the 216 engine of the AD series trucks had dipper oiled rod bearings. GMC was always one step ahead of Chevrolet when it came to engine engineering... Mike B  | | |
