Those are available from Jim Carter. Link. I bought a pair for my truck. It originally had one correct one and one hex head bolt in place. Or if you can find them locally, I believe they're oval head phillips 1/4-20 machine screws.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
