| | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 31 Apprentice | | Apprentice Joined: Sep 2004 Posts: 31 | Ben told 67-72 2 ton chev. automatic differential will fit 1948 chev fire truck. Does anyone know where I can find one. ANYWHERE. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | What size 48 truck? If you are sure you know what you need, try an ad in the parts wanted section. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | What model is that '48? Or at least what series? 4000, 5000 or 6000?
That would narrow what rear is most likely under it now. But also, there were choices available and a fire truck might have something that was not standard in the first place.
Some truck rears were used for years and under a number of different trucks.
As Grigg said the first thing is to be sure what you need, and that starts with knowing what you have.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | All firetrucks that I've looked at 1950 thru 1953 all had the two speed rear end due to heavy water load and large firetruck weight load. | | | | | Joined: Sep 2004 Posts: 31 Apprentice | | Apprentice Joined: Sep 2004 Posts: 31 | This 48 firetruck is a 6400 2 ton. It has a single speed rearend and everything is stock. We take it to parades sometimes as far as 200 miles one way.This rearend should be 6:10. The truck has 7000 miles original. We don't have a trailer. | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | hey lutrexen, i'm in kansas city, and about 30 west of me in Oskaloosa Kansas, there is a big truck salvage, i can think of the name right off, but the have a lot of older grain trucks chevy/ford/international 1940's- nowdays stuff. i'm sure you could find something there, only hour and a half away from you, pm if your still interested, and i'll get the name for you 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | |
