2 members (Otto Skorzeny, 1 invisible), 102 guests, and 1 robot.
Topics128,154
Posts1,056,856
Members48,456
#152049 04/12/2007 12:00 AM
Junior Member
Junior Member
i just checked the gear oil on my 55 dump and it is white and frothy... I am assuming this isn't good, but what is causing it? The engine oil looks OK (black as hell, but no froth). The previous owner blew a head gasket, but claimed he had it fixed. Thanks!
#152050 04/12/2007 12:05 AM
In my experience, water. Could be due to rain leaking in from above, could be due to water condensing in the compartment due to cold / hot changes.
It's definitely not good. Change the oil and hope nothing is permanently damaged beyond repair.
#152051 04/12/2007 12:07 AM
Junior Member
Junior Member
It sounds like you've gotten water in the oil. Check the seals and the vent line for any blockages. If you don't have a vent line, I'd plan on adding one.
#152052 04/12/2007 12:11 AM
ccogg,
It's pretty standard for gear lubes to froth up when the rig has been run. While the foam might appear whitish, the lube itself should remain its natural dark color. Motor oil and water, when mixed will create the often seen 'milkshake'. Is this what you are describing.
Stuart
#152053 04/12/2007 2:01 AM
One more vote for water. I'll bet somewhere along its life, the truck has been driven or been in water above the axles. That'll let water in through the vent and sometimes the seals, too. That's why serious off roaders alway carry extra gear lube wiht them if the expect to run in water. Usually, they'll change the oil before they make the trip home in case of contamination.
Bill Burmeister
#152054 04/12/2007 2:18 AM
Junior Member
Junior Member
Well I just changed out the oil (it was in the transmission not the rear diff). I filled it with some motor oil I had and drove it around the block, then drained it again (still frothy, but better). Now I am going to fill it with 90w and see how it looks after the next trip.
Where would I look for vents? Any other ideas on how the water got in there? It was very thick and frothy and it just doesn't seem too likely that it was driven that far under water - but of course anything is possible!
Thanks for all the help!
#152055 04/12/2007 2:47 AM
Is there a water leak in the cab under the dash?
It will usually drip right on the gear shifter and then into the tranny. frown
GMC: Get More Cash...
1958 GMC
My Webshots photos
#152056 04/12/2007 3:04 AM
Junior Member
Junior Member
I will check the cab - thanks!!!
#152057 04/12/2007 3:16 AM
you might just have 50 years of condensation built up - no tellin if the trans oil was ever changed, and in a wet climate the alternate heating and cooling would do it for ya
#152058 04/12/2007 3:20 AM
My bad. I assumed you were talking axles, not tranny. Wouldn't be a bad idea to check the axle, though. The Oil is probably the same age/condition as the trans.
Bill Burmeister
#152059 04/12/2007 4:45 AM
Junior Member
Junior Member
Actually the axle oil looked fine. I filled the gear box with 90w and drove it a bit. When I checked it this time it was more like milk - it was like whip cream before. I guess I will change it a 3rd time.
Also, it happens to be raining right now and there is no leak apparent under the dash. The window seal leaks, but it doesn't drip on the gear shift. The mystery continues...
#152060 04/12/2007 9:29 PM
did the 55 have a vent drain like the 47-54? its a rubber hose that drains the main front vent when it rains, the hose runs down on top of the back of the motor, maybe this could lead water back down and on the trans?
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
