2 members (Otto Skorzeny, 1955 1 Series), 89 guests, and 4 robots.
Topics128,031
Posts1,055,436
Members48,422
#1518500 09/21/2023 2:08 PM
I believe I'm ready to go. Excited yahoo
breezy #1518507 09/21/2023 2:56 PM
Might as well come install mine when you’re done!
What did you do for a driveshaft there? Have one built?
1951 3100
breezy #1518508 09/21/2023 3:02 PM
Driveshaft is from another 50s truck with open drive line. Will have to be shortened but have a local guy on call to do it. Conversion joint in front for t5 to 50 shaft. Middle joint is replacement joint for 50.
breezy #1518513 09/21/2023 3:43 PM
If you're having the driveshaft shortened, you can have your guy install a yoke that matches the T5 yoke so you don't have to hunt down a conversion joint if/when it needs replacement.
breezy #1518515 09/21/2023 3:47 PM
I have the same joint at rearend so no biggie. Common joint on the shelf at flaps
breezy #1518525 09/21/2023 4:19 PM
breezy,
Is this going in a 3600 (3/4 ton)???
You don't have a signature line and didn't say what your working on. So just making a guess. grin
Yes/No/Maybe So???
Dan
EDIT: Asked as a 3100 can get a way with a 1-piece driveshaft, although a 3200 with 2-piece driveshaft could go the same route as your pictured parts.
~ Dan
1951 Chevy 3 window 3100
breezy #1518532 09/21/2023 4:37 PM
Started life as a 3600. Now it's a 5/8 ton maybe. Lol
breezy #1518547 09/21/2023 7:42 PM
Here we go!!
breezy #1518553 09/21/2023 8:30 PM
And where out.
breezy #1518556 09/21/2023 8:57 PM
And were back in.
breezy #1518573 09/21/2023 10:51 PM
O Online: Content
Marathon Man!
1950 Chevrolet 3100 (Ol' Roy)
breezy #1518577 09/21/2023 11:02 PM
Was going good tell the carrier bearing bolt holes won't line up and has to drop down 1 1/4". But I'm on it.
breezy #1518669 09/22/2023 6:39 PM
Carrier bearing problem solved. But with a question.
Option 1 made a spacer and bolted generic GM carrier bearing to it.
Option 2 found what could be considered the correct carrier bearing but haven't a clue what it's from. I took it from a 63 c60. But everything I look up for that doesn't show that setup?
So anyone know what it's from? Thanks
breezy #1518696 09/22/2023 9:20 PM
breezy,
Any stamped numbers on it anywhere???
~ Dan
breezy #1518708 09/22/2023 10:05 PM
No numbers
breezy #1518712 09/22/2023 11:10 PM
Too bad about no numbers.
Just a note that the size and spacing looks good for what your doing, but the lack of that rubber flex support may lead to some pretty serious vibrations and possibly early wear out of the u-joints???
Just thinking out loud here. wink
~ Dan
breezy #1518715 09/22/2023 11:28 PM
It has rubber around the bearing and is actually greasable..
Truck has the same thing now just with enclosed drive shaft. So it should be fine. No problems now.
breezy #1518716 09/22/2023 11:34 PM
breezy,
Below are some pics taken from a 1966 Chevrolet Special Parts and Illustration Book I have that show the 2 different carrier bearing setups you show.
Your 1st pic seems to match up with the common 3/4 Ton carrier bearing (with the rubber insert) design in my 1st pic.
Your 2nd pic seems to match up with the larger truck (1 Ton through 2 Ton) carrier bearing design which my book says was used for the 1941-54 and later year large truck 2 and 3 piece driveshafts.
Offered to help ID what you found and hopefully clear up any mystery about the 2nd carrier bearing unit. smile
Dan
EDIT: Glad to hear what you found will work out for you!
Common carrier bearing design
1941-54 and later 1 Ton thru 2 Ton carrier bearing.JPG (100.5 KB, 99 downloads)
Larger truck (1 Ton thru 2 Ton) carrier bearing design
~ Dan
breezy #1518717 09/22/2023 11:38 PM
Thanks Dan. That helps a lot. Guess they don't make them that way anymore. Have to adapt like I already did. I'm going to use the ole original one. Still good after all these years. Probably last longer than the replacement.
breezy #1518732 09/23/2023 12:39 AM
Nice progress.
breezy #1518733 09/23/2023 12:43 AM
Should be rolling tomorrow. Waiting for buddy at machine shop to cut drive shaft down. Lugnutz how much fluid this trans hold?
breezy #1518759 09/23/2023 5:21 AM
Does the carrier bearing not line up because the T5 is longer? The added length plus the piniom angle makes it offset? Or is there something else going on?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
breezy #1518774 09/23/2023 10:52 AM
Original carrier bearing was fine. Problem was it was attached to a closed drive line
So I had to come up with a replacement for the open drive line.
I didn't want to destroy the closed drive line trying to remove carrier since I wasn't sure how it came apart.
But an FYI you can't buy a replacement carrier in original form that's why I made the adapter piece. Hope that answers your question.
breezy #1518777 09/23/2023 11:44 AM
The adapter that you made will work just fine. I've done that on 4 different 3/4 ton trucks already with no issues
breezy #1518778 09/23/2023 11:46 AM
Oh I'm confident it will. But I found that original one and cleaned it up. It's greasable also. So until it fails I'll run it
breezy #1518793 09/23/2023 2:07 PM
Should take just under 3 quarts. Fill it until it is level with (and runs out of) the fill hole on the side. Use Dex/MERC ATF.
breezy #1518795 09/23/2023 2:11 PM
breezy #1518801 09/23/2023 3:27 PM
Getting really close now.
breezy #1518813 09/23/2023 4:53 PM
Well it's done. First trip out went well. No shakes. Shifted fine. Overdrive not the greatest. Not enough power and to high rearend ratio. 2.73. .073 overdrive. .086 would be much better. But did get to 67 mph. So speed is there. Time for 3.08 gears I would say. That should get me what I'm looking for. But overall it's great. Forgot how sloppy these s10 shifters were. Have to address that also. Thanks for all the advice and help. Special thanks to lugnutz for even going as far as a phone call. Great guy there!!!
breezy #1518815 09/23/2023 5:08 PM
Side note. Without floor pan cover it's a hot sum itch.
breezy #1518818 09/23/2023 5:19 PM
Moderator, Electrical Bay
Good job! .86 5th gear with 3.07 or 3.08 is a good option. Don't know which gear ratio chain you have but the chain beginning with 4.03 and a 3.07 rear will let you use your pickup as a real genuine 1/2 ton truck and still drive on the highway at around 2100 rpm.
~ Jon
breezy #1518819 09/23/2023 5:21 PM
Need to just put the 235 in. Maybe this winter. But probably still need some gears. Thanks
breezy #1518844 09/23/2023 8:52 PM
Calling it a day. Not a beautiful piece of work but will keep the critters out until I get the correct cover.
breezy #1518859 09/23/2023 10:41 PM
Mine ain’t buttoned down either.
breezy #1518868 09/24/2023 12:09 AM
How it happened but my after-market shift lever broke off. I had to have it welded back on. It was welded to the factory cover plate. Mine has a 2.73 Nova rear axle. 5 the gear and 65 mph barely over 2100 rpm. BTW 15 inch tires.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
WE b OLD #1518869 09/24/2023 12:28 AM
Maybe 15” wheels, but what tire diameter?
breezy #1519294 09/26/2023 11:34 PM
Did the same with mine. I have .72 5th gear. The factory 4.56 at 70 mph It is turning 2500 with 16 inch wheels . The little 216 surprises me everyday. Not sure on tire size. I did away with center bearing and had one piece shaft made from transmission to rear with same joints on both ends. Best improvement yet.
breezy #1519300 09/26/2023 11:50 PM
I'm loving it. 3.08 gear would be better but having a synchronized transmission is really a great improvement. Got the shifter made today. What a crap feast that was. Got it done but it would be nice if you could buy some decent dies these days. Irwin sucks. Snap no better. I think I could have chewed better threads.
breezy #1519321 09/27/2023 1:44 AM
0.76 and a 3.90 with 28.66" tires make a good combination with my 216. Best modification I've done on the truck so far.
