| | | Forums66 Topics128,113 Posts1,056,580 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 126 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 126 | 1946 chevy cabover with two speed axle. Need good parts website and service instructions or would it be wise to simply upgrade to a modern axle? :confused: | | | | | Joined: Nov 1995 Posts: 5,729 24601 | | 24601 Joined: Nov 1995 Posts: 5,729 | Cajun, The guys who know ought to be along soon.
Is there anything wrong with your axle now? Or do you just want to service it?
Bill Marlow has a '46 COE and we have a bunch of other guys who are experts on these things can probably tell you where to find stuff. I found some parts for my '49 2-speed at NAPA. I want to replace seals and bearings next, so answers to your questions should help me, too.
Thanks for using the Stovebolt Page!
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | what doesnt work on it first? the cable shift, the shifter mechanism... or in the rear vacuum motor?
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | John the seals & bearings are all available from the Flaps. The instructions are in the shop manual or repair manual. That stuff is big & heavy. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 190 | I would like to replace my seals to, I must ask - whats the flaps? Thanks watching + Listening and hopefully learning. | | | | | Joined: Sep 2006 Posts: 126 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 126 | Well fatweed Im in the process of just trying to replace what I think will be necessary for road ready service:(bearings, seals,diff oil and what ever it takes to make that two speed safe and very functional. | | | | | Joined: Sep 2006 Posts: 126 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 126 | John milliman thanks for the napa tip. I will check with the napa people in the morning.  | | | | | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | the two speed itself does work then? i guess for pm, if it doesnt howl and shifts ok. you could replace the pinion seal, but i wouldnt if it isnt leaking, and maybe the wheel seals, but there again if they arent leaking. You could change the gear lube if ya want. If its workin ,as the old adage goes dont fix it...???? if the two speed isnt working or shifting, its probably the rubber diaphram on the rear end. easiest way to check that is pull both vaccum lines, and pull vacuum on it and see if either side leaks.... can even just suck on it. to make it shift or move though would take probably a little more than ya can suck....
if its the shifter mechanism on the frame thats run from a cable, you can usually i think just clean those up and replace o rings i think, dont remember rebuilding one for sure...
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If it shifts, does not leak much, and there is no watter in the lube then I would leave it alone for now and try it out on the road for a while.
After that you may have a better idea of what work it may or may not require. When you replace your rear brake shoes it would be a great idea to replace the outer axle seals and clean and inspect the rear hub bearings.
Grigg | | | | | Joined: Sep 2006 Posts: 126 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 126 | You guys are a great help. There is no sign of leaks as i can and for what I have as a history it was not an over worked truck. I will drive it after doing some brake work and inspecting outer seals and inspect the hub bearings as Grigg has mentioned. | | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | I found a service manual for the Eaton 2-speed rear on line here. Better than buying one or getting greasy fingerprints on yours. Old Chevrolet Manuals On-Line
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
