9 members (rfs56trk, 50Chevy3100, 3800GUY, cmayna, Donf, Barry Martak, Peggy M, Lightholder's Dad, 1 invisible), 117 guests, and 2 robots.
Topics128,092
Posts1,056,461
Members48,443
1946 chevy cabover with two speed axle. Need good parts website and service instructions or would it be wise to simply upgrade to a modern axle? :confused:
1946 Chevy 1.5-Ton Flatbed
Photobucket
Old Big Trucks are built to last.
24601
Cajun,
The guys who know ought to be along soon.
Is there anything wrong with your axle now? Or do you just want to service it?
Bill Marlow has a '46 COE and we have a bunch of other guys who are experts on these things can probably tell you where to find stuff. I found some parts for my '49 2-speed at NAPA. I want to replace seals and bearings next, so answers to your questions should help me, too.
Thanks for using the Stovebolt Page!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
what doesnt work on it first? the cable shift, the shifter mechanism... or in the rear vacuum motor?
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
Riding in the Passing Lane
John the seals & bearings are all available from the Flaps. The instructions are in the shop manual or repair manual. That stuff is big & heavy.
1972 Chevy c10 Cheyenne Super
I would like to replace my seals to, I must ask - whats the flaps? Thanks watching + Listening and hopefully learning.
Well fatweed Im in the process of just trying to replace what I think will be necessary for road ready service:(bearings, seals,diff oil and what ever it takes to make that two speed safe and very functional.
Photobucket
John milliman thanks for the napa tip. I will check with the napa people in the morning. grin
Photobucket
the two speed itself does work then? i guess for pm, if it doesnt howl and shifts ok. you could replace the pinion seal, but i wouldnt if it isnt leaking, and maybe the wheel seals, but there again if they arent leaking. You could change the gear lube if ya want. If its workin ,as the old adage goes dont fix it...???? if the two speed isnt working or shifting, its probably the rubber diaphram on the rear end. easiest way to check that is pull both vaccum lines, and pull vacuum on it and see if either side leaks.... can even just suck on it. to make it shift or move though would take probably a little more than ya can suck....
if its the shifter mechanism on the frame thats run from a cable, you can usually i think just clean those up and replace o rings i think, dont remember rebuilding one for sure...
If it shifts, does not leak much, and there is no watter in the lube then I would leave it alone for now and try it out on the road for a while.
After that you may have a better idea of what work it may or may not require.
When you replace your rear brake shoes it would be a great idea to replace the outer axle seals and clean and inspect the rear hub bearings.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
You guys are a great help. There is no sign of leaks as i can and for what I have as a history it was not an over worked truck. I will drive it after doing some brake work and inspecting outer seals and inspect the hub bearings as Grigg has mentioned.
Photobucket
I found a service manual for the Eaton 2-speed rear on line here. Better than buying one or getting greasy fingerprints on yours.
Old Chevrolet Manuals On-Line
195? Chevy 3800 dump truck
1973 Chevy C30 cab and chassis
1987 Suburban 3/4 ton 6.2L Diesel
