0 members (),
102
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | Have any of my fellow big bolters changed out their rear seals recently? I need a part number for the inner rear axle seal for a 53 6400 with a 2 speed rear end the one i took out is about 4 5/8" OD with a 3 1/8" ID hole and it is about 1/2 " thick. it has definately been in and out a few times prior to me owning the truck! this leaking seal would account for the brakes locking up every now and then.
Thanks in advance Darrell | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy D Sinclair, I have looked that seal up in my CR catalog using your dimensions shaft 3.125" X 4.626" bore X .438" thick, CR p/n 31299, hope that helps. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | There should be a part number on the seal that a competent parts house can cross-reference for you. That's what I did when the 48's seal went bad, Scott | | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | Thanks 3B thats great I will go get a couple on monday the ones I took out had no numbers on them anywhere and I thought the bolters would have some ideas. I like that online seal cataloge 3B I will add that to my favorites ASAP. Thanks again Darrell | | |
