5 members (Bisbee, Steve_H, Otto Skorzeny, Bill Hanlon, 54farmtruck), 143 guests, and 4 robots.
Topics128,148
Posts1,056,813
Members48,454
51 250 series 1 ton GMC. Pulled the front end off to remove motor and found what appears to be 70+ year old rubber seals. Or, are these after market because I can’t find them anywhere online at the regular vendors ? Should I consider a similar configuration at one of the weatherstrip manufactures for other applications?
What do you think those were for?
Reduce heat transfer to the upper support? Or just dust /dirt seals
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Looks like a seal to ensure all incoming air is directed through the radiator rather than around it.
I think it's unlikey that you will find a replacement but that's just a guess. If you have a factory assembly manual it would help you determine the GM part number and from there you could start researching if a replacement can be found.
Ron - - Dusty53
1954 Chevy 3604
Moderated by  Dusty53
