| | | Forums66 Topics128,185 Posts1,057,286 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2023 Posts: 17 'Bolter | | 'Bolter Joined: Aug 2023 Posts: 17 | hello everyone i have a 1964 chevy bus i am trying to find drums for and it is difficult does anyone have any leads on a good place to find drums and maybe shoes
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | What size bus are we referring to? Drums for the larger trucks/buses are just not reproduced. Salvage is about the only way. Some of the smaller trucks have some availability.
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2021 Posts: 430 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 430 | you need to size your drums. as in all the dimensions. Then find a large truck web site that has those dimensions and search. Because "Marketed" to your specific year may not be out there BUT actually they exists. "Reproduced" can actually just be under another make and model even modern. Some things are not reproduced but Drums and Pads and Calipers often show up under all kinds of years makes and models. Now not saying the unicorn is out there but I would start there. I know some guys have had luck with smaller truck drums and 1 tons this way. The internet has made finding unicorns much easier. (and harder sometimes the old paper catalogs had very good indexes/charts).
So give us the details. Year make and model and what those dimensions are and we can help you look.
Best of luck.
| | | | | Joined: Aug 2023 Posts: 17 'Bolter | | 'Bolter Joined: Aug 2023 Posts: 17 | it is a 1964 chevy cassis with a blue bird body dimensions on the drum ar as follws height 8 inches pilot hole 6 1/2 stud to stud 8 7/8 stud diameter 3/4 10 stud count | | | | | Joined: Jan 2022 Posts: 2,499 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,499 | None of those dimensions are large enough to describe the inside diameter of the brake drum.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Is there a data plate on the firewall from Chevrolet? Is there a Service Parts Identification plate somewhere on the bus (normally on the glove box door)? Lets see them... Have you pulled the drums? Measure the drum inside diameter and shoe width (example 15 x 4). Do you know they are out of spec and can't be turned? Any big truck service shop should be able to turn them for you and reline your shoes. Mike B  | | | | | Joined: Aug 2023 Posts: 17 'Bolter | | 'Bolter Joined: Aug 2023 Posts: 17 | | | | | | Joined: Aug 2010 Posts: 607 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 607 | Wow, that's big for front drums. My C60 has 14x2 1/2" drums and they're well past spec. The local truck place can line the shoes with double thickness linings to make them the same size as the enlarged drum, however I too have been looking for a set of new drums. I'm starting to look more seriously at converting to disc, there seem to be more options out there nowadays.
| | | | | Joined: Aug 2010 Posts: 607 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 607 | As I mentioned elsewhere, I was eventually able to find a pair of new Webb front brake drums-local, and at a fair price!
| | | | | Joined: Aug 2010 Posts: 607 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 607 | I found this Accuride page for the obsoleted Gunnite 2770 drum. It also has cross references to Webb (64401) and a bunch of GM and other vendor part numbers. Might be a good place to start. https://www.accuridecorp.com/products/2770
| | | | | Joined: Aug 2023 Posts: 17 'Bolter | | 'Bolter Joined: Aug 2023 Posts: 17 | thats crazy i work at fleetpride and didnt come across these until now thank you | | | | | Joined: Aug 2010 Posts: 607 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 607 | You're welcome. I hope you can track 'em down. Also Fleetpride shows the front drums available Webb P/N 64425 14x2.5" and can verify they fit perfect on the 5,000lb front axle. Also, maybe you can get an employee purchase discount :-)
