4 members (Ridgeback, fonz8261, SNOYL, Oswald), 207 guests, and 2 robots.
Topics128,087
Posts1,056,115
Members48,435
#1513870 08/21/2023 6:51 PM
What’s the trick for zeroing these?
59 3E 3600
Moderator, Electrical Bay
Well, well, well. This question comes up from time to time and what we have here is a deep pond full of murky water plus several confused alligators. There is a federal law which says "oh you can't do this no matter what." Specifically:
A person may not–
(1)advertise for sale, sell, use, install, or have installed, a device that makes an odometer of a motor vehicle register a mileage different from the mileage the vehicle was driven, as registered by the odometer within the designed tolerance of the manufacturer of the odometer;
(2)disconnect, reset, alter, or have disconnected, reset, or altered, an odometer of a motor vehicle intending to change the mileage registered by the odometer;
(3)with intent to defraud, operate a motor vehicle on a street, road, or highway if the person knows that the odometer of the vehicle is disconnected or not operating; or
(4)conspire to violate this section or section 32704 or 32705 of this title.
(Pub. L. 103—272, § 1(e), July 5, 1994, 108 Stat. 1049; Pub. L. 103—429, § 6(33), Oct. 31, 1994, 108 Stat. 4380.)
And then that part of the law you just read is followed by what I call the "tag on the left door and get out of jail free section" which says:
(a)Adjusting Mileage.–A person may service, repair, or replace an odometer of a motor vehicle if the mileage registered by the odometer remains the same as before the service, repair, or replacement. If the mileage cannot remain the same–
(1)the person shall adjust the odometer to read zero; and
(2)the owner of the vehicle or agent of the owner shall attach a written notice to the left door frame of the vehicle specifying the mileage before the service, repair, or replacement and the date of the service, repair, or replacement.
(b)Removing or Altering Notice.–
A person may not, with intent to defraud, remove or alter a notice attached to a motor vehicle as required by this section.
(Pub. L. 103—272, § 1(e), July 5, 1994, 108 Stat. 1049.)
And then if you're still awake there is the mileage disclosure statement that comes into play when you sell the vehicle. And there are some attorneys who claim it doesn't apply to vehicles over 10 years in age and if you simply write "exempt" you can ignore that disclosure statement or you can tell the buyer all you know about the mileage numbers from the past. Which (if they are correct pretty well gives 10+ year old vehicles a hall pass):
https://tinyurl.com/wp5mjnay
But hold on a minute...can you rely on that 10 year stuff? Well, not in Texas and possibly not in your state, either. January 1, 2021 Texas adopted a brand new state law increasing the age to 20 years. So a vehicle made in 2003 would be exempt but a vehicle made in 2004 wouldn't be. And if you're coming from out of state (from a state adhering to the 10 year plan) and you have for example a 2011 vehicle which (in your previous state) was legal with an "exempt" mileage disclosure statement then we're just going to assume nobody in the world really knows and we'll mark it Not Actual Mileage for the Texas title.
So what is the deal here? I don't know but I would do my best to retain the mileage amount on the speedometer before you do anything. In my particular case that's a complete impossibility. Somebody who owned my pickup in California replaced the speedometer when the original one died with another used one. I know that because the date stamped on the back was 1953 when I removed it. And when that one croaked I went to a junkyard and bought a replacement used speedometer (one from 1951 or 1952...can't recall now) which had fewer miles than the one which had died (which wasn't correct anyway). And when I changed transmission, I went with an electronic one (for accuracy) and later replaced it with a GPS unit (for even more accuracy)...but with those electronic units you can not alter the mileage unless you own some really sophisticated equipment. So I can give an honest statement of what I think it is, but remember...I have no earthly idea what the mileage on that original speedometer that failed in CA was.
So I would sincerely suggest you check the laws in the great state of Georgia before you do anything.
~ Jon
I have posted free decal templates here before in case you wanted to clean your numerals up a bit...
https://www.stovebolt.com/ubbthread...dometer-numeral-renewal.html#Post1398540
~ Jon
I’ve zeroed my Gremlin every time I rebuilt him.. i’ve had that car since ‘98. He’s not for sale (ever).
Ima zero this truck. She’s also not for sale. Blahblahblah
AMC has a lock-tab you can depress and free spin the #s. I’m not finding one on here .. so I assume it has to be disassembled from the worm gear and then it’ll free spin.
59 3E 3600
P.s.I’m thinking there’s a checkbox for “exceeds odometer reading” for Big Brother’s rules and regulations
59 3E 3600
O Online: Content
Yes, Georgia is pretty lax about anything to do with antique cars and hot rods. Build whatever you want and drive it.
We have no inspections or anything so the gummint doesn't know anything about what your mileage is or was or should be. As mentioned, there's a space on the title that says odometer reading is inaccurate.
1950 Chevrolet 3100 (Ol' Roy)
Yup, the Gremlin is registered as a “custom”… because of his hotrod mods 👍
This truck may get the same 🤷🏻‍♀️ (I probably got another year before I’m finished with her… but yeah, she’s not stock)
59 3E 3600
Gents,
Due to legality reasons, we should not be talking about zeroing odometers. If you want to talk about cleaning fixing, etc, that is fine. If in the cleaning/fixing directions you zero it, that is on you.
Please tread carefully!
Chris
Authorized Pest
Authorized Pest
"Zeroing odometers" ?? - nono
We have an old Tech Tip by Squeeze -- Odometer Refurbishing. It's for a Task Force truck.
If anyone has refurbished their odometer for other years, why not give us another TT! thumbs_up
~ Peggy M
1949 Chevrolet 3804
24601
Not sure that zeroing your odometer violates any law -- perhaps one of our DOT/LEO community can weigh in and enlighten us.
Pretty sure, though, that zeroing your odometer, and then claiming its actual mileage in a legal document, such as a bill of sale or a title transfer, *is.*
In my own case, Charlie's speedometer has been disconnected for more than 20 years. When I finally get around to fixing that ... with a rebuilt unit, I will have the odometer set to what I think is the actual mileage (an estimate on my part). And the difference between that and zeroing it is ... what ... ? Either way is fine as long as you fess up to it when you need to.
On the other hand, I could reconnect my speedometer as is and go on and let someone think its actual mileage. And the difference between *that* and zeroing it out is what??
I think you all are thinking too hard about this.
When I did a couple of frame offs, a '39 half ton and a '49 1.5-ton, I got the speedos rebuilt both times and reset to zero. I documented that the original mileage was unknown and that the new mileage shown was "since restoration."
No one ever had an issue with that.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
John,
Thanks for adding your post. If I’m in the wrong, I have no issues stepping back and admitting it. I just didn’t want to see it causing future issues on here.
Chris
I am in Missouri, I reset my odometer when I rebuilt it, took the truck to Highway patrol for inspection to get new title. They nor the DMV had anything to say abut mileage. DMV simply wrote down what I told them, zero. My guess is, being it's from the '30, no one expects the mileage to be correct, or really cares if it is.
Cleaning and rebuilding an odometer is nothing more than removing clips and a few screws to make a pile of parts. Add a new decal set, reassemble in the order of which it came apart, and go about your business. Use light oil on the speedometer, and minimum oil on rotating parts.
It's up to you on how you handle selling the thing. Take pictures, print them out, before and during the rebuild. File them away with the title.
As far as legality of resetting an odometer to zero, the only right answer is to check with your state Motor Vehicle Department. It'll likely be a different answer for each of the 50 states.
Moderated by  ndkid275, Phak1
