0 members (), 97 guests, and 2 robots.
Topics128,132
Posts1,056,729
Members48,454
For the record… the factory manual I got is trash 😾
59 3E 3600
I have zero idea what im doing obviously
59 3E 3600
What sequence do these “extra pieces” go on? Are they even necessary? I think I still have one (or 2?) still on the shaft.. does it need to be replaced?
59 3E 3600
Hey Turry draw me like one of your French girls… i mean, a diagram of components 😸
59 3E 3600
Gelalfett , can you please verify Model and year truck you are working on. Pics of what you've removed would also be helpful. Using the picture you provided, leave that deflector on the shaft. Then install one of the grease retainers big face out towards bearing, then the carrier bearing then another grease retainer big face in towards bearing and finally the dust shield small side first.
Ron - - Dusty53
1954 Chevy 3604
The FAM is not a replacement for the Shop Manual. If you are working on a 1959 truck, you'll need the 1955 shop manual along with the 56, 57, 58 and 1959 Supplements, they didn't rewrite the complete manuals for 56 thru 59, they just added any new items into that years supplement.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Gelalfett,
All of the shop manuals and supplements Mike B mentioned (except for the 1957 & 1958 Supplements) are available to peruse and use for free at The Old Car Manual Project as well as a whole bunch of other fantastic resources that are just a few clicks away. The parts manuals can also be a big help as they often contain exploded diagrams that better display how components like your carrier bearing setup go together.
I use the site many times a day and find it easy and very useful.
On a related note, it would help everyone reading/responding to your posts if you would either include the specifics of the truck your are working on (make/model/year at least) in the post itself, or you could add a "signature line" like many of us use that provides details about your truck so you don't have to constantly type in that info.
Just a suggestion that will help you and us. wink
Dan
~ Dan
1951 Chevy 3 window 3100
This is what i took off 🤷🏻‍♀️
59 3E 3600
59 3E 3600
When you pull stuff like that apart, you should lay each piece in line on the table in order of removal so you can see how it all stacks up when it's time to reassemble it.
1950 Chevrolet 3100 (Ol' Roy)
59 3E 3600
Using an angle grinder and cutoff wheel like that, unless you were REAL CAREFUL, you likely damaged the shaft (hopefully not enough to destroy it.) The proper way to remove a carrier bearing is to use a puller or shop press.
The re-assembly process is covered on the 55 2nd series Shop Manual on page 4-67. Link
Well that was fun (not really)
The secret weapon for seating that bearing seems to be a random pipe with a 1 3/8 id & 1 29/32ish od (if anyone ever asks)
-thanks y’all
59 3E 3600
