7 members (51sub, 41 chev, WICruiser, Oldpickupman, Gdads51, Charles in CA, 1 invisible),
92
Mod | | | Forums66 Topics128,265 Posts1,058,360 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | I have a 1938 GMC pickup, I have been trying to figure out the serial number for a while. The only numbers I can find are the model # 114b and chassis # 350** then it has a straight rating of 4590. Would the chassis number be the same as serial number ???
1938 Gmc 1/2 ton
| | | | | Joined: Sep 2010 Posts: 1,732 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,732 | Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Sep 2009 Posts: 6,204 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,204 | TheShoer, Am sure you know there isn't a lot of online readily available info on GMC trucks, especially those back in the 1930's. Can you provide a picture of the data plate to help try and deduce what you have??? I did a bit of searching and found a picture from an old 1938 GMC sales document that seems to give a list of the offered Model #s, but "114b" wasn't one of them. Could you be mis-reading the numbers? I found model#s "T14" (1/2 Ton) and "T145" (3/4 Ton) that could relate to the "114b", but without a way to see it for ourselves, not really able to help confirm. This older thread 1938 GMC Serial # location may help you find what you are looking for. Let us know what you find out.  Dan EDIT: Wayne beat me to the posting button - LOL! Thanks Wayne - your info is probably a whole lot more helpful than mine
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Mar 2003 Posts: 316 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 316 | The number is probably T14B, which corresponds to the longer wheelbase. The vehicle serial number is stamped on the passenger side of the frame rail around the front spring perch.
| | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | TheShoer, Am sure you know there isn't a lot of online readily available info on GMC trucks, especially those back in the 1930's. Can you provide a picture of the data plate to help try and deduce what you have??? I did a bit of searching and found a picture from an old 1938 GMC sales document that seems to give a list of the offered Model #s, but "114b" wasn't one of them. Could you be mis-reading the numbers? I found model#s "T14" (1/2 Ton) and "T145" (3/4 Ton) that could relate to the "114b", but without a way to see it for ourselves, not really able to help confirm. This older thread 1938 GMC Serial # location may help you find what you are looking for. Let us know what you find out.  Dan EDIT: Wayne beat me to the posting button - LOL! Thanks Wayne - your info is probably a whole lot more helpful than mineIt is T 14 B the T was not stamped very good and dies look more like a 1
1938 Gmc 1/2 ton
| | | | | Joined: Sep 2009 Posts: 6,204 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,204 | Looks like the answer to the Model number question is cleared up. Thanks for coming back and letting us know! Are you still seeking answers on the "chassis #"??? Looks like from what "dunfire" said, the "chassis #" is the same as the serial number. As mentioned, you should be able to find the stamped number "on the passenger side of the frame rail around the front spring perch". Dan
