Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (J Lucas, Sjm), 115 guests, and 1 robot.
Topics128,285
Posts1,058,534
Members48,490
#151221 02/26/2007 12:32 AM
Apprentice
Apprentice
Greetings fellow Big Bolters,
I'm currently working on an old 1949 1.5t grain truck. I need to inspect and bleed the brakes and I'm having trouble getting the rear drums off. I've removed the wheels, end cap, axle, both threaded retainer rings and I can see the outside bearing (which is loose).
That's where I'm stuck. The drum spins freely, but will not pull off. If it's just stuck, maybe I can get my wife to break it free. Is there a secret pin or lock that I'm missing?
Cartman
#151222 02/26/2007 1:49 AM
3B Offline
Hy Cartman, the drum may have a ridge worn into it at the inboard end which will allow it to only move a bit before it hits the ridge. See if you can back the shoe adjustment down to clear the ridge, hope that helps.
#151223 02/26/2007 4:43 AM
Apprentice
Apprentice
Wrench Fetcher,
Thanks for the advice. I never thought of that, but that's exactly what it feels like. As soon as the sun comes up tomorrow, I'll give it a shot.
Cartman
#151224 02/26/2007 4:56 AM
Hey Cartman you would be talking to 3B Wrench Fetcher would be his standing on the board. By the way welcome aboard hope 3B's hint helps you out. Good luck and looking forword to seeing you around.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
#151225 02/27/2007 4:29 AM
Apprentice
Apprentice
HevyHauler,
I stand corrected; still learning the ropes with the site. 3B's advice solved the problem. With a little adjustment, the drums slid right off. It was my first time on a big truck and I was afraid I'd break something that would be hard (or impossible) to replace.
Thanks.
Cartman
