0 members (),
171
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 20 Apprentice | | Apprentice Joined: Feb 2007 Posts: 20 | Greetings fellow Big Bolters,
I'm currently working on an old 1949 1.5t grain truck. I need to inspect and bleed the brakes and I'm having trouble getting the rear drums off. I've removed the wheels, end cap, axle, both threaded retainer rings and I can see the outside bearing (which is loose).
That's where I'm stuck. The drum spins freely, but will not pull off. If it's just stuck, maybe I can get my wife to break it free. Is there a secret pin or lock that I'm missing?
Cartman | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Cartman, the drum may have a ridge worn into it at the inboard end which will allow it to only move a bit before it hits the ridge. See if you can back the shoe adjustment down to clear the ridge, hope that helps. | | | | | Joined: Feb 2007 Posts: 20 Apprentice | | Apprentice Joined: Feb 2007 Posts: 20 | Wrench Fetcher,
Thanks for the advice. I never thought of that, but that's exactly what it feels like. As soon as the sun comes up tomorrow, I'll give it a shot.
Cartman | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Hey Cartman you would be talking to 3B Wrench Fetcher would be his standing on the board. By the way welcome aboard hope 3B's hint helps you out. Good luck and looking forword to seeing you around. | | | | | Joined: Feb 2007 Posts: 20 Apprentice | | Apprentice Joined: Feb 2007 Posts: 20 | HevyHauler,
I stand corrected; still learning the ropes with the site. 3B's advice solved the problem. With a little adjustment, the drums slid right off. It was my first time on a big truck and I was afraid I'd break something that would be hard (or impossible) to replace.
Thanks.
Cartman | | |
