1 members (Shade Baby), 152 guests, and 8 robots.
Topics128,106
Posts1,056,214
Members48,436
#1510888 07/28/2023 1:48 PM
I’ve decided to buy a NOS AC 4149 and a rebuild kit from Then and Now and am looking for help removing the valves. I have experimented on the old Airtex one I took off with no luck. They look to be a press fit and I have not been able to budge them. Any insights from someone who has done this?
Blue 50
1950 3100 w/57 235
Patrick’s Saginaw 4 speed and 3:55 rear end
The airtex one has screws holding it together or just clamped?
1951 3100
Looks to be a press fit. No screws
Blue 50
1950 3100 w/57 235
yes, press fit no screws.
Mike
So can I just punch those out? This is a parts pump to practice on. How do I install the new valves without damaging them?
Blue 50
1950 3100 w/57 235
You'll need to fabricate a fixture to push the check valves into the housing without putting any pressure anywhere except the outer edge. That shouldn't be much of a challenge for anyone with basic machining skills and the right tooling. An arbor press or just a heavy duty C clamp should be needed.
Well that leaves me out. I have no fabrication/machining/tooling skills or equipment.
Blue 50
1950 3100 w/57 235
Maybe try to find a small socket from a quarter inch set thats just right size to
chase those check valves in, with a c-clamp, as Jerry suggests.
Not too hard.
~Charley
1954 Chevy 3100 with 235
“Bud”
Follow along in the DITY
1963 Chevy half ton stepside short box 230
1954 GMC 3 ton 302
And several more Chevy camper and work trucks 1979 1987 1996
Once you get the old ones knocked out, a socket the right size and a bench vise would probably work to push them back into the housing. Make sure they face the right direction so the flow is toward the carburetor- - - -they're both the same part, just a one way spring loaded valve. The tension of the spring provided in the rebuild kit controls the output pressure of the pump.
Thanks to you both for the info. Probably going to be next weekend before everything gets here, I will post an update then.
Blue 50
1950 3100 w/57 235
What is included in the rebuild kit, and what does it cost? I'm tempted to buy one, and fabricate the tooling needed to install the check valves as a demonstration project. I have a sneaky suspicion an ammunition reloading press could be adapted to install those check valves, once the fixtures are fabricated.
www.ebay.com/itm/314674075134?
Blue 50 #1510974 07/28/2023 10:33 PM
Cadillac fuel pumps that I've rebuilt in the past had similar valves. They just pressed in by hand and then were staked around the edge to keep from popping out per the shop manual.
1950 Chevrolet 3100 (Ol' Roy)
Blue 50 #1510975 07/28/2023 10:34 PM
Make sure to take note of inlet and outlet orientation. Do one at a time.
