6 members (Oswald, 2-Ton, TexasJim50, stlcardinalsguy, 1955 1 Series, Otto Skorzeny), 66 guests, and 5 robots.
Topics128,180
Posts1,057,157
Members48,464
So I have decided to install the shocks in the original position but I need to know if the upper mount is bolted on the frame or riveted or welded on the frame at the top. I had one and ordered a new one.rear suspension.. It looks like it could have been bolted or pop-riveted. But not showing the bolts for sale like in other things I am not sure.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Ron,
According to the "General Description" paragraphs of Section 2-3 (Shock Absorbers) of the 1954 Shop Manual the rear shocks "Attachment at the upper end is to a bracket riveted to the frame.".
That was how the came from the factory. Since yours were removed at one point, the easiest method to reinstall them would be to bolt them back on using appropriate grade hardware.
Not very likely you will find a shop that can/will rivet them back on correctly unless you have a very deep pocket.
Dan
~ Dan
1951 Chevy 3 window 3100
Bolt them on! Grade 8 bolts. I did that on my 49.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Thanks all. I had thought they had been riveted back in the day. I am now waiting for the new bracket to get it done.
2017 Buick Encore
See more pix
Anybody, what to speculate on the length of the bolts?
2017 Buick Encore
See more pix
