0 members (), 99 guests, and 3 robots.
Topics128,113
Posts1,056,619
Members48,450
2 Offline
I have a Question about decent used clutches.
Recently (like a day ago) I removed to inspect the clutch from an engine and bell housing that I plan to use in a farm truck
The clutch is a 10-3/4 inch size for a 1 to 1952 gmc
3 of 6 springs in the clutch disc center are broken but complete
No bits fell out
So I went looking in the used clutch pile in my shed
And most of them all have a broken spring or two
Is this actually super normal and I shouldn’t worry about it for a beater farm truck?
These disks are not even fully worn out
Or should I find a clutch disc with all good springs
The engine it’s going on is a 235 and the transmission is the sm420
Thanks for any thoughts or advice
-s
I think even for a farm truck, I'd get a replacement clutch disk. All it would take is for a broken spring to slip out of the disk and wedge against the flywheel bolt heads and make it impossible to release the clutch. If you already have it apart, now's the time to put new parts in place.
. ...and broken will cause chatter.
2 Offline
What causes the springs to break
Quality? Or were these abused? Maybe SK roads just make all vehicle things broken.
I’ll shop for a new clutch yeah it’s a pain to drop the transmission.
-s
