4 members (Ponchogl, TUTS 59, Otto Skorzeny, Hotrod Lincoln), 128 guests, and 1 robot.
Topics128,126
Posts1,056,353
Members48,441
#150670 02/02/2007 9:34 PM
Junior Member
Junior Member
I found this truck in a neighbor's barn. Had not run in 10 years since the prevous owner passed away. We put in a set of points, a battery, bypassed the fuel tank which seems to be stopped up and drove it home carefully since the only brakes that work is the emergency brake! Anyway,
there is a sticker on the door that says rated at 16000 pounds and engine horsepower 109 at 3600rpm. Can someone tell me if this is a 6500 and what engine it has. This is my first post and I will post a picture as soon as I figure out how!Thanks
welcome to the shop hope, is it a 55 1st or 2nd?
the 55 2nd has a 6400 model with 16,000 GVW that has a 156.5" WB, called a 2 ton, and the vin would start with a W - the 109hp engine would be the usual 235, prolly the loadmaster version in a 6400
for info about pictures here, see the Manual linked below, we love pictures grin
Junior Member
Junior Member
It is a 2nd series. Where is the serial number located? I working on pictures!
vin plate should be on the drivers door post above the dogleg or lower on the wide area - might also be stamped on the frame top flange around the steering box, but that was just starting then, so might not be there
Junior Member
Junior Member
#150675 02/02/2007 10:08 PM
Junior Member
Junior Member
I'm going back to the barn and look for that plate. In the meantime put in a couple more pics!
[img]http://thumb9.webshots.net/t/59/459/5/99/77/2160599770100433169MWAEHh_th.jpg[/img]
#150676 02/02/2007 10:11 PM
Junior Member
Junior Member
#150677 02/02/2007 10:23 PM
Junior Member
Junior Member
Okay, found the serial number W255F 020042
#150678 02/02/2007 10:34 PM
W = 6400
2 = 2nd series
55 = 1955
F = Flint plant
20,042nd off the line there
#150679 02/02/2007 10:41 PM
Junior Member
Junior Member
Thanks Bill, I was looking at the pictures of other trucks like this one and noticed that mine has a hood ornament that I don't see on other trucks like this. It this something that was orginal to this truck os has someone added this. It looks like the emblem you might see on a 55 chevy car!
http://community.webshots.com/user/hope55chevy
#150680 02/02/2007 11:12 PM
Nice looking truck!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Mike here has some good info. He is a Stovebolter but He's not around a lot however you can drop him an e-mail.
http://www.chevytrucks.org/mikesgarage/
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
that hood bird/plane was an accessory option in 55-56, can't see yours well enuff to tell if it's the right one, but notice that Mike Boteler has one on his restored wrecker - see the difference 55-56 here
you do have the correct emblem on the front of the hood, but are missing the fenderside emblems, which would have the '6400' designation on them
Hope & red58,
The serial numbers for second series 1955 trucks started with number "001001". This makes Hope's truck the 19,042nd "W" unit out of Flint.
I have most of this info listed on my web site.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
