1 members (Ole49GMC),
109
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 18 Junior Member | | Junior Member Joined: Jan 2007 Posts: 18 | I found this truck in a neighbor's barn. Had not run in 10 years since the prevous owner passed away. We put in a set of points, a battery, bypassed the fuel tank which seems to be stopped up and drove it home carefully since the only brakes that work is the emergency brake! Anyway, there is a sticker on the door that says rated at 16000 pounds and engine horsepower 109 at 3600rpm. Can someone tell me if this is a 6500 and what engine it has. This is my first post and I will post a picture as soon as I figure out how!Thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | welcome to the shop hope, is it a 55 1st or 2nd? the 55 2nd has a 6400 model with 16,000 GVW that has a 156.5" WB, called a 2 ton, and the vin would start with a W - the 109hp engine would be the usual 235, prolly the loadmaster version in a 6400 for info about pictures here, see the Manual linked below, we love pictures Bill | | | | | Joined: Jan 2007 Posts: 18 Junior Member | | Junior Member Joined: Jan 2007 Posts: 18 | It is a 2nd series. Where is the serial number located? I working on pictures! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | vin plate should be on the drivers door post above the dogleg or lower on the wide area - might also be stamped on the frame top flange around the steering box, but that was just starting then, so might not be there
Bill | | | | | Joined: Jan 2007 Posts: 18 Junior Member | | Junior Member Joined: Jan 2007 Posts: 18 | | | | | | Joined: Jan 2007 Posts: 18 Junior Member | | Junior Member Joined: Jan 2007 Posts: 18 | | | | | | Joined: Jan 2007 Posts: 18 Junior Member | | Junior Member Joined: Jan 2007 Posts: 18 | Okay, found the serial number W255F 020042 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | W = 6400 2 = 2nd series 55 = 1955 F = Flint plant 20,042nd off the line there
Bill | | | | | Joined: Jan 2007 Posts: 18 Junior Member | | Junior Member Joined: Jan 2007 Posts: 18 | Thanks Bill, I was looking at the pictures of other trucks like this one and noticed that mine has a hood ornament that I don't see on other trucks like this. It this something that was orginal to this truck os has someone added this. It looks like the emblem you might see on a 55 chevy car! http://community.webshots.com/user/hope55chevy | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Mike here has some good info. He is a Stovebolter but He's not around a lot however you can drop him an e-mail. http://www.chevytrucks.org/mikesgarage/ | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | that hood bird/plane was an accessory option in 55-56, can't see yours well enuff to tell if it's the right one, but notice that Mike Boteler has one on his restored wrecker - see the difference 55-56 here you do have the correct emblem on the front of the hood, but are missing the fenderside emblems, which would have the '6400' designation on them Bill | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Hope & red58, The serial numbers for second series 1955 trucks started with number "001001". This makes Hope's truck the 19,042nd "W" unit out of Flint. I have most of this info listed on my web site. Mike B  | | |
