| | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2022 Posts: 162 'Bolter | | 'Bolter Joined: Feb 2022 Posts: 162 | What is the best oil to run for a rebuilt 51, 216?
1953 with a 216
| | | | | Joined: Sep 2009 Posts: 5,777 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,777 | Luray,
Are you asking for before or after your initial rebuild break-in run?
Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Feb 2022 Posts: 162 'Bolter | | 'Bolter Joined: Feb 2022 Posts: 162 | Before , then after break in
1953 with a 216
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I've used 15-40 in 216 and 261's and prefer it. | | | | | Joined: Sep 2009 Posts: 5,777 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,777 | It all boils down to personal preference. When I go to do a freshly rebuilt engine break-in run, I will spend the extra money and purchase an appropriate amount of SAE 30 Engine Break-In oil similar to THIS PRODUCT. The Shop Manual guidance says to run the break-in oil for the first 500 miles, then change out with fresh oil that matches the current temperature and expected running conditions expected for your truck. You can certainly run a multi-viscosity oil, but would recommend you don't do that until after the initial break-in period. Others will chime in here with more info and personal preferences, but this is just my $.02 worth on the subject. Dan
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | IIRC the original recco was 20. | | | | | Joined: Feb 2022 Posts: 162 'Bolter | | 'Bolter Joined: Feb 2022 Posts: 162 |
1953 with a 216
