1 members (Hotrod Lincoln), 77 guests, and 4 robots.
Topics128,271
Posts1,058,312
Members48,485
#1506647 06/24/2023 8:05 PM
What is the best oil to run for a rebuilt 51, 216?
1953 with a 216
Luray #1506663 06/24/2023 9:26 PM
Luray,
Are you asking for before or after your initial rebuild break-in run?
Dan
~ Dan
1951 Chevy 3 window 3100
Luray #1506669 06/24/2023 9:48 PM
Before , then after break in
1953 with a 216
Luray #1506680 06/24/2023 11:04 PM
I've used 15-40 in 216 and 261's and prefer it.
Luray #1506681 06/24/2023 11:06 PM
It all boils down to personal preference.
When I go to do a freshly rebuilt engine break-in run, I will spend the extra money and purchase an appropriate amount of SAE 30 Engine Break-In oil similar to THIS PRODUCT.
The Shop Manual guidance says to run the break-in oil for the first 500 miles, then change out with fresh oil that matches the current temperature and expected running conditions expected for your truck.
You can certainly run a multi-viscosity oil, but would recommend you don't do that until after the initial break-in period.
Others will chime in here with more info and personal preferences, but this is just my $.02 worth on the subject.
Dan
~ Dan
Luray #1506689 06/24/2023 11:45 PM
IIRC the original recco was 20.
Luray #1506700 06/25/2023 12:25 AM
1953 with a 216
