8 members (Ridgeback, GMCJammer51, Biermann, Danielbolt, sron48, GIJOE298, Phak1, DadsFirstPickup), 111 guests, and 3 robots.
Topics128,154
Posts1,056,835
Members48,456
My sheet metal is all coated with epoxy. It is all past the recoat time, Which I think was 5 or 7 days. The instructions say to scuff it after that time. What should I scuff it with to prep it for 2K Urethane primer?
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
Get a few 3M scuff pads. They work well to put a little “tooth” on the epoxy.
What brand epoxy did you use?
I use SPI, which if left to induce overnight instead of the normal 30 minutes, tends to thicken up a bit and give it better build properties. If I were doing this (since the 7 day window is expired) I’d use the opportunity to block out the panels and find highs/lows, metal bump a bit to address, then follow up with another dose of epoxy followed by your high build if desired.
That's good advice from Robert on blocking now. I think the epoxy I'm using has a 5 day recoat window without scuffing.
The epoxy I used was Kirker. But some of the metal was sandblasted commercially, and the blasting guy put epoxy on it after blasting. I have no idea what brand he used.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1947 Indian Chief
1943 Indian 741
I don't think the brand used by the blasting folks will have any impact since the repaint window is long closed. Block it , find the lows / highs, bump , fill , sand, recoat and get ready for that finish coat. I use black epoxy for the epoxy recoat after blocking/repair because it makes it very easy to see any imperfections and I have a chance to repair them before the finish coat.
Mike, we all really like pictures of your work....we are kinda strange that way.
Ron - - Dusty53
1954 Chevy 3604
The data sheet that the manufacturer provides with the primer as well as well as the surfacer should specify the treatment needed.
Mike
1940 Chevy 1/2 Ton presently... Almost done
1940 Chevy Business Coupe... In pieces
