4 members (HandyAndy, gswbbc, JW51, Donf), 113 guests, and 4 robots.
Topics128,040
Posts1,055,478
Members48,424
#1505910 06/19/2023 3:50 PM
What do I need to see if this is the original engine or not.
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
T-Doug #1505918 06/19/2023 4:12 PM
Doug, should be an engine serial number on the little pad behind the distributor. It'll date the block, but the head could be from another engine/year.
T-Doug #1505926 06/19/2023 5:02 PM
Doug,
Probably the best identifiers for figuring out just what engine you have boils down to 2 primary things.
1st is the Serial# stamped into the block. Check out this resource which provides info on where to find your serial number and help breaking down what the stamped numbers mean.
2nd part needed is to find and verify your "block" casting code and date info. Check out this resource link with pictures for help on that.
The pictures you posted above show the "head" casting info, which helps identfy that part, but not the basic engine block details.
Get some pictures of your block info and post them here so we can offer more help if you can't determine them from the links provided.
Dan
~ Dan
1951 Chevy 3 window 3100
T-Doug #1505949 06/19/2023 9:03 PM
When I get home from my shop tonight I'll edit the pic here.. Thanks for the pointers in the right direction.
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1505971 06/19/2023 11:55 PM
Well now. The serial number block is blank.
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1505972 06/20/2023 12:03 AM
It sounds like you've got a "replacement" block, one that a Chevy parts department sold to be used during an overhaul. The casting number down close to the fuel pump will give you an idea of the engine's age and basic application, but casting numbers usually span several years of production.
T-Doug #1505975 06/20/2023 12:20 AM
If possible, find and post here the following:
1. Block casting code
2. Block date casting code
3. Head casting code
4. Head date casting code
5. Engine Serial Number (a replacement engine might not have an ESN, or it might have an odd ESN)
T-Doug #1505980 06/20/2023 1:14 AM
I’m not going to remove the starter to get to the casting date. There are no other numbers on that side of the block.
I’ll get my mirror out to make sure I didn’t miss anything hidden behind the distributor or fuel pump.
I double checked with a mirror and nothing.
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1505987 06/20/2023 2:09 AM
Doug,
There are numbers/letters on that pad in your picture. They are partially visible if you use the magnifying button when viewing your picture. You just need to do some more cleanup of that pad, probably with a wire brush, to clear the heavy layers of paint and old grime buildup to bring them into the light of day.
Your block casting code, assuming you have a '54 235 engine, will be just above the oil pan mounting flange rail between the front of the engine block and the fuel pump mounting location (see attached screenshot). Those will also probably be heavily obstructed with old grime and paint, which a wire brush will expose.
Dan
PS - The engine block date casting codes are visible just above your starter if you get the angle just right. No need to remove the starter.
Typical '50 - '54 235 Casting code location
~ Dan
T-Doug #1505989 06/20/2023 2:18 AM
I'm seeing a 6 (or maybe 5), a 3, a 5, maybe a 2, and an X in your picture. Get a wire brush and clean it up some more. Lighting it from the side also helps you read the stamped numbers. [on edit] on second look, that 2 looks like a 4, and a 54X indicates a 54 235 engine originally installed in a 3100. If you find an F in front of the 5, that would indicate it came from the Flint plant, and a T would indicate the Tonawanda Plant.
The casting number should be under the fuel pump and just above the pan gasket. Not that hard to find.
[on edit] Dan beat me to the punch while I was out double checking on my 216 (which is what your 54 should have if original) Nope 54's had a 235.
T-Doug #1506031 06/20/2023 12:24 PM
AD Addict & Tinkerer
If you blow up your picture, you can clearly see numbers and letters stamped on that pad. Clean it with a wire brush as Kevin suggested and it may clear it it.
Phil
Project Journals
Stovebolt Gallery Forum
T-Doug #1506046 06/20/2023 3:09 PM
Use a wire brush or sandpaper on the pad, then rub it with welder's chalk or white soap. The numbers will pop up pretty clearly.
T-Doug #1506191 06/21/2023 3:42 PM
You guys have better eyesight than me for sure. I’ll give it another cleaning and try again.
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1506193 06/21/2023 4:09 PM
This looks a lot better.
The one above the starter I could only kind of make out the last 3 and it looked like N30.
Still can’t find the one up forward.
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1506221 06/21/2023 8:10 PM
Yep, pretty clear. That's a 54 engine originally installed in a 3100, built in the Flint plant.
T-Doug #1506225 06/21/2023 8:21 PM
That’s good to know. Makes it highly likely the original motor.
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1506229 06/21/2023 8:37 PM
I finally found the casting number. Best guess is 388P011
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1506267 06/22/2023 12:13 AM
Revisit your block casting number and see if it's 3835911 (1954/55 235)
There is nothing about your truck that's "original", you have a 1954 engine, a 1955 frame and 1956 sheet metal...it's a frank-n-truck!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
T-Doug #1506315 06/22/2023 3:44 PM
That looks right Mike. Thanks
1954 Chevy 3100
Montgomery, AL
In Project Journals
