4 members (FishinToms53, klhansen, Otto Skorzeny, Southerntruck), 98 guests, and 2 robots.
Topics128,118
Posts1,056,646
Members48,450
Moderated
Moderated
I have a 1947 3600 truck that I would like to replace the transmission in. It is in great condition and I use it as a daily driver. It has a 4 speed transmission that I just can not get the hang of down shifting in it and I end up grinding the hell out of the gears. I don't think it has any synchromesh gears in it. I would like to keep the original 216 engine. I am hoping that there is some sort of an adapter out there that will bolt up to the 216 and allow me to bolt on a newer 4 speed standard transmission. I would be happy with any 4 speed transmission. If there is an adapter what would you recommend for a replacement transmission. Is there any other recommendations out there?
Mark Elhart
Similar to this? T5 trans adapter
Mark,
I think in this case the OP is looking to upgrade his "crash box" transmission with a later SM420 that at least has synchro's in 2nd - 4th gears, instead of changing to a T-5 5 speed.
I am pretty sure there have been a number of conversations about doing just that. Going to let others with more knowledge than I have chime in here and offer some help.
Dan
~ Dan
1951 Chevy 3 window 3100
The SM420 has a different bolt pattern than the old sliding gear transmission. A clutch housing that fits a SM420 will fit your engine, but the engine mounts will be different. The fix we did 60 years ago was to replace the 1947 and earlier cross member with a 1948-1953 cross member. It has been many years since I saw a conversion done and I don't remember all the details. But a 48-53 clutch housing, cross member and as SM420 is doable. And my generation did it when we were teenagers in the 1950's so it wasn't all that complicated.
Tried to send you a PM but won't go thru. I have the modified bellhousing that you need.
Moderated
Moderated
Hello Dave, if you want to email me any information you have that would be great. Please email me at [email protected]
Thank You.
Mark Elhart
