| | | Forums66 Topics128,128 Posts1,056,670 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2023 Posts: 2 Moderated | | Moderated Joined: Jun 2023 Posts: 2 | I have a 1947 3600 truck that I would like to replace the transmission in. It is in great condition and I use it as a daily driver. It has a 4 speed transmission that I just can not get the hang of down shifting in it and I end up grinding the hell out of the gears. I don't think it has any synchromesh gears in it. I would like to keep the original 216 engine. I am hoping that there is some sort of an adapter out there that will bolt up to the 216 and allow me to bolt on a newer 4 speed standard transmission. I would be happy with any 4 speed transmission. If there is an adapter what would you recommend for a replacement transmission. Is there any other recommendations out there?
Mark Elhart
| | | | | Joined: Oct 2005 Posts: 4,258 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,258 | Similar to this? T5 trans adapter | | | | | Joined: Sep 2009 Posts: 5,977 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,977 | Mark,
I think in this case the OP is looking to upgrade his "crash box" transmission with a later SM420 that at least has synchro's in 2nd - 4th gears, instead of changing to a T-5 5 speed.
I am pretty sure there have been a number of conversations about doing just that. Going to let others with more knowledge than I have chime in here and offer some help.
Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | The SM420 has a different bolt pattern than the old sliding gear transmission. A clutch housing that fits a SM420 will fit your engine, but the engine mounts will be different. The fix we did 60 years ago was to replace the 1947 and earlier cross member with a 1948-1953 cross member. It has been many years since I saw a conversion done and I don't remember all the details. But a 48-53 clutch housing, cross member and as SM420 is doable. And my generation did it when we were teenagers in the 1950's so it wasn't all that complicated. | | | | | Joined: Sep 2012 Posts: 222 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 222 | Tried to send you a PM but won't go thru. I have the modified bellhousing that you need. | | | | | Joined: Jun 2023 Posts: 2 Moderated | | Moderated Joined: Jun 2023 Posts: 2 | Hello Dave, if you want to email me any information you have that would be great. Please email me at [email protected]Thank You.
Mark Elhart
