Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (54farmtruck, UtahYork), 48 guests, and 6 robots.
Topics128,003
Posts1,055,244
Members48,418
#1504841 06/12/2023 1:27 AM
I have been looking at Steering Gears and wanting to convert to power steering. I have found that I need a reverse steering gear. Has anyone else found reverse steering gears that would work? I have seen lots of part numbers and from what the supplier sites say they are reverse, but then some other place says the same part number is standard rotation. I want to keep my box in the same location so I want to go with a reverse box. I have seen trucks with the same part number used in 1 tons and 2 tons. So I am thinking that a 1 ton gear from a modern truck would be fine for replacing a '56 manual gear. Some of the models I have looked at are the 2002 Kodiak truck, 2002 1 ton Chevy Express van. Many trucks and have also looked at reversing the gear box from a guy who describes it on the HAMB. I want to stay away from mounting it outside the frame or in front of the axle.
1956 Chevy School Bus Superior Body
Crusing in the Passing Lane
There is a modern steering box to fit in the old location that fits a Toyota(don’t laugh) Pittman arm to the new box that fits in the old hole. CPP probable source. Otherwise a modern Delphi(Saginaw) box can be inserted outside the frame(special mounting required) to do the job. Some fabrication required! Other options exist for two tons utilizing modern(‘99-‘02+-) hubs/spindles without tires sticking outside fenders!
Ed
EdPruss #1506151 06/21/2023 5:13 AM
I have looked at that CPP option for a while. I am wondering if it is a good option. I have discussed this very gear with another member and it may not be. However, my bus is only a 4500 and shorter than a full size extended cab truck. So my thinking was kind of like if the CPP one is used for the 3100 pickups why not mine. Would a 1 ton modern gear be as good if not better than a 1956 1.5 ton gear?
fclaridge #1506274 06/22/2023 12:49 AM
I'd be afraid to use anything smaller that 1-1/2 ton rated, the last thing you want to have happen is for something to break when you hit a pot hole at 60 mph.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
That's something I am heavily considering for sure. I live somewhat close to Redhead Steering Gears and I think I am going to pay them a visit in person to see what they have. I think I looked at a few possibilities for size and strength that I can fabricate a mounting adapter for and make work. I'll see.
I mounted my power steering box ahead of the axle, outside frame. Got a die and shortened drag link in ‘55.2.
Ed
fclaridge #1511829 08/03/2023 11:12 PM
Moderated
Moderated
Is that the P30 spindle? Thanks
P-3500 HD.
Ed
