8 members (TooMany2count, 55shaker, Guitplayer, Otto Skorzeny, Peggy M, TexasJim50, Bill Hanlon, cmayna), 141 guests, and 5 robots.
Topics128,259
Posts1,058,292
Members48,485
#1504674 06/11/2023 12:18 AM
Want to try to paint the lettering of the tailgate. Any specific kind of paint I should use? .don't want to use the lettering kit.truck has the rat rod look.
1953 with a 216
O Online: Content
In that case use barn paint and a brush.
1950 Chevrolet 3100 (Ol' Roy)
Sign paint would also be vintage/rat rod appropriate. I agree that using a brush would give you that look as well.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
I use rustoleum alkyd gloss and a 1.5" angled brush.
1962 C10 with a 235 6cyl -- all of the drive train seems to be original.
Some of this story is in the Side Lot
Some people like a new truck. I liked the old ones.
1953 with a 216
Be aware that a lot of primers are not UV stabilized, so they will deteriorate pretty quickly outside if not covered up.
I would recommend actual flat paint if you want that look.
You could also consider using Sign Painters' 1 Shot lettering enamel. It comes in many colors.
I had forgotten about that stuff. I used to use it all the time and it was great.
Question. If you are spraying it, how are you masking it? How do you make sure you get good sharp edges? I guess same question if you are using a brush. If you are using a brush are you free handing it or masking and coloring between the lines.
Dave from Northern Kentucky
My 54 3100
I believe the trick with spraying is to mask it, spray your base color and let it dry. Then spray your alternative color. The base color will bleed under the tape, but it won't matter because it matches the rest. That leaves no where for the alternative color to bleed to. You still need to be accurate in your taping skills.
