3 members (asilverblazer, wvstovebolt, Bill Hanlon), 135 guests, and 3 robots.
Topics128,083
Posts1,055,967
Members48,430
#150410 01/22/2007 1:13 PM
I
Junior Member
Junior Member
I Offline
my truck currently has 7.25 x 20 tires, if I get 8.25 tires will they be taller and wider or just wider. these tires seem to be more available.
#150411 01/22/2007 4:54 PM
3B Offline
Hy indianajay, 8.25" tires are both taller and wider than 7.50" tires, hope that helps.
#150412 01/22/2007 5:24 PM
Indianajay, You shouldn't have any problems running 8.25 x 20 tires, on your truck. I presently have 8.25 x 20's all the way around my '53 Chevy COE. Have ran 9.00 x 20's, on it, in the past.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#150413 01/22/2007 11:42 PM
I think you'll need the rims that come with the 8.25's. They're an inch wider than the 7.50 wheels. I had to do this with my 48,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#150414 01/23/2007 3:23 AM
I
Junior Member
Junior Member
I Offline
i'll do some measuring, I found a tire dealer today that keeps these in stock, he said they have no problems changing tires on split rims. thats always a good sign. tell you the truth the 7.50 tires that are on the truck now have a huge gap between the back tires at least 2 to 3 inches. they don't look right. they could stand to be alittle wider.
