| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 31 Junior Member | | Junior Member Joined: Nov 2006 Posts: 31 | my truck currently has 7.25 x 20 tires, if I get 8.25 tires will they be taller and wider or just wider. these tires seem to be more available. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy indianajay, 8.25" tires are both taller and wider than 7.50" tires, hope that helps. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Indianajay, You shouldn't have any problems running 8.25 x 20 tires, on your truck. I presently have 8.25 x 20's all the way around my '53 Chevy COE. Have ran 9.00 x 20's, on it, in the past. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I think you'll need the rims that come with the 8.25's. They're an inch wider than the 7.50 wheels. I had to do this with my 48, Scott | | | | | Joined: Nov 2006 Posts: 31 Junior Member | | Junior Member Joined: Nov 2006 Posts: 31 | i'll do some measuring, I found a tire dealer today that keeps these in stock, he said they have no problems changing tires on split rims. thats always a good sign. tell you the truth the 7.50 tires that are on the truck now have a huge gap between the back tires at least 2 to 3 inches. they don't look right. they could stand to be alittle wider. | | |
