2 members (greenie-reddy, carbking), 47 guests, and 7 robots.
Topics128,021
Posts1,055,355
Members48,420
#150284 01/17/2007 5:42 PM
Can you put a 19.5" tire onto a 20" rim?
#150285 01/17/2007 6:10 PM
Also, what are yalls feelings on retreaded tires? yay or nay? and any good sources would be appreciated.
#150286 01/17/2007 6:23 PM
No, the tires are not the same size. 19.5's amount to an 18" tubeless in laymans terms. Good quality retreads are fine for rear axles. I 've run Bandag cold caps on drive axles and trailers of my semi's and never had a problem. Bandag will only cap perfect carcesses. Just don't trust them for steering axles. Got better milage from the caps than new tires.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#150287 01/17/2007 6:47 PM
ok, my next question, what is the widest tire i can run on the rear axle without rubbing issues?
#150288 01/17/2007 7:17 PM
53moneypit What does a 22.5 measure?
A 1965 Chevy C-60 2-Ton Flatbed
A 1953 Chevy 1/2-Ton
A 1949 Chevy Business Coupe
#150289 01/18/2007 6:51 AM
I
I Offline
Not sure what year your putting them onto, but on my 40 1 1/2 ton I just put on 8.00-20s. They didn't rub and were a bit taller which was nice to have.
#150290 01/19/2007 1:31 AM
I disagree with 53 moneypit on retreads. your buying a tire that has already been wore out once.When they blow they can tear up anything nearby. Everytime a tire sales man talks my boss into trying a new process cap we wind up sitting on the side of the road waiting for road service, fixing lights, mud flaps etc. they take out not to mention if the tire pieces hit another vehicle. The current truck I drive is a lease deal all they run on drives are recaps. blew 4 of the first 8 and 2 so far of the second 8.
