| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 63 | Can you put a 19.5" tire onto a 20" rim? | | | | | Joined: Dec 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 63 | Also, what are yalls feelings on retreaded tires? yay or nay? and any good sources would be appreciated. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | No, the tires are not the same size. 19.5's amount to an 18" tubeless in laymans terms. Good quality retreads are fine for rear axles. I 've run Bandag cold caps on drive axles and trailers of my semi's and never had a problem. Bandag will only cap perfect carcesses. Just don't trust them for steering axles. Got better milage from the caps than new tires. | | | | | Joined: Dec 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 63 | ok, my next question, what is the widest tire i can run on the rear axle without rubbing issues? | | | | | Joined: Jan 2002 Posts: 36 Member | | Member Joined: Jan 2002 Posts: 36 | 53moneypit What does a 22.5 measure? | | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | Not sure what year your putting them onto, but on my 40 1 1/2 ton I just put on 8.00-20s. They didn't rub and were a bit taller which was nice to have. | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | I disagree with 53 moneypit on retreads. your buying a tire that has already been wore out once.When they blow they can tear up anything nearby. Everytime a tire sales man talks my boss into trying a new process cap we wind up sitting on the side of the road waiting for road service, fixing lights, mud flaps etc. they take out not to mention if the tire pieces hit another vehicle. The current truck I drive is a lease deal all they run on drives are recaps. blew 4 of the first 8 and 2 so far of the second 8. | | |
