| | | Forums66 Topics128,054 Posts1,055,780 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 38 Apprentice | | Apprentice Joined: Apr 2006 Posts: 38 | Its been a while since i said hello. Last time i was jibbering on about buying a 49 maple leaf, but could not come at the work involved. So i settled for a '42 mapleleaf truck for more cash.
The first job is to strip down and work on the chassis and brakes. I was wondering what type of brake fluid is used in these old trucks? I it the modern stuff or the older mineral type fluid? | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | I believe you want to stay away from the silicone types. Those types used in the 70's would be fine. Here the rating would be DOT 3 have no idea what the ratings would be over there. Some of the more knowledgeable folks will be around after while. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Hey wombat, Got any Maple Leaf pictures. Especially of the ''47-'52 style. | | | | | Joined: Dec 2006 Posts: 184 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 184 | For what it's worth, I've used standard brake fluid in my 39 for the last 14 years. It's a wee 3/4 ton though, so I don't know if the big trucks use the same or not. | | | | | Joined: Apr 2006 Posts: 38 Apprentice | | Apprentice Joined: Apr 2006 Posts: 38 | Thanks guys, It sounds like the normal stuff will be fine?
You know how? Every one keeps going on about.
'I fired up the old girl, she has been sitting for 25 years and in under 30 mins she was purring like a kitten' I been busting to see if it true?
Well yesterday i put it too the test!
'Condensation in the oil, and filled up the radiator, checked for a point gap and gas connected to the carbie and in under 30mins 'She was a Purring'
'Unbelievable' | | |
