7 members (JoergK., BarryP, Hugh63c10, Gdads51, Pre '68 Dave, 2-Ton, 1 invisible), 315 guests, and 3 robots.
Topics128,164
Posts1,057,076
Members48,463
Moderated
Moderated
I'm working on a father/daughter project - 1950 Canadian Made 1434 (3800) with a dump box. The rear end seems to be geared to only go 30mph max. I heard that Canadian rear ends have axles and pots specific to those rear ends and cannot be swapped out with US-made ones. Is this correct? How can I identify what rear end I have? Any help or suggestions would be appreciated. Thanks.
I bet if you post some pics of the rearend someone here will tell ya all about it 👍👍
1962 C10 with a 235 6cyl -- all of the drive train seems to be original.
Some of this story is in the Side Lot
Some people like a new truck. I liked the old ones.
2 Offline
It should have a 5.14 rear end
You can drive it about 50-55 mph
Don’t be shy
I have one of mine in my back yard right now full of construction waste, it’s a 9433 but would have the same rear end. I drove it 105 km from my farm two days ago
I kept it between 80-90 kmph (50-55 mph)
Constant the whole way
Check the rotations per mile specification on your specific rear tires, multiply that by the rear end and that gets you the engine rpm for 60mph in highest 1:1 gear
Example:
620 rotations per mile tire
be 620x5.14= 3200 rpm for 60mph
So going only 50-55 is about 2670-2930 rpm
I think I have 255/85 r16 tires on it but they are fairly worn down so new they would have been about 610 rotation per mile
Original tires on a 1434 were almost 34 inches diameter
So don’t expect to go as fast if you have a smaller 30.x inch diameter tire now.
Also don’t be afraid of the front tire hitting the fender
Mine look like they have about 1/2 inch clearance at full turn
But they have never touched metal in 70 years
I have stock suspension and non of the box weight goes onto the front axle in any meaningful way
And I’ve been running on rough pot holes and fields and ditches in Saskatchewan.
As far as I know the issue is you can’t swap only the ring and pinion gears with USA models because the bolt pattern is different on the gear itself, the whole rear end internals will swap is my understanding.
-s
Looking at the ends of the rear axle it looks to be an Eaton HO52 but having photo's of the front/rear of the rear differential would be helpful. 2ManyTrucks is correct, would need to swap the entire carrier if wanting to go to the 4.11. The 4:57 would be easier to locate, I believe.
Ron - - Dusty53
1954 Chevy 3604
Moderated
Moderated
Thanks - I'll post more pictures of the rear axle tonight when I get home.
Hi Ron, welcome to the Stovebolt site.
It took a while but I managed to find a 4:10 complete rear axle assembly out of a 67 to 72 3/4 ton they are out there. Check out the tech section on this upgrade lots of information to help you with it.
Good luck in your search.
1950 Chevrolet model 1434 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
You will never stop learning new things, no matter how old you are.
Moderated by  Dusty53
