11 members (TooMany2count, Woogeroo, cmayna, Jay R, Rusty Heaps, TexasJim50, TUTS 59, Hotrod Lincoln, Otto Skorzeny, Forty9, 1 invisible),
94
Mod | | | Forums66 Topics128,134 Posts1,056,411 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 1,365 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,365 | First off, my lack of knowledge here is total. That out of the way, I've installed a 12v radio in my 6v truck with the help of a step-up transformer (?) from ebay. Works great. The radio's currently mounted on the front of the seat sorta outta sight. I plan to move it to the glove box and to that end bought a longer antenna cable, this one. The problem is not knowing what a Motorola end was, that's what I have on the antenna end of the cable. My question is what do I need to buy to replace the Motorola end so I can screw the coax to the antenna. A web site or link would be great! Thanks for any help. RonR
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Sep 2013 Posts: 1,365 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,365 | Thanks for the response, I should have added the radio isn't a vintage unit but this one. Has bluetooth, remote and very compact size. I have every confidence that a very few years ago I could have visited Radio Shack, rummaged around a bit and found what I needed. Oh for the old days.....sometimes.
RonR
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you have the same connector system on the radio as your antenna than you just need an extension. If the radio has a different connector style then that is a different story. You could give these folks a try with an Email Gary Tayman | | | | | Joined: May 2023 Posts: 26 'Bolter | | 'Bolter Joined: May 2023 Posts: 26 | Here is what you need. they come in all sizes. Extension
1960 Chevy C10 gasser- Rabble Rouser 1953 Harley Davidson Panhead chopper
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Thanks for the link. Those older antenna items don't show up in the store much anymore. Our Walmarts up here have almost completely done away with Automotive items for sale. | | |
